Question about Brother MFC-8860DN All-In-One Laser Printer
My Brother 8860DN will not scan legal size documents--what should I do?
old marine
  • 1985 Answers
SOURCE: Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
Posted on May 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: how to scan legal documents on Canon MF5770?
This information is available on CANON WEBSITE
Unfortunately, they imbed the text in javascript, and there is no way to link or c/p the information here. Try THIS HYPERLINK to take you to the exact page.
Enter your model # in "search knowledgebase" at the above link.
Type PAPER SIZE
You will have a clickable link that says How do I specify paper Size and Type.
Instructions will appear.... starting like this... (i used C/P, and it may not come out slearly after I submit this answer)
Issue: How do I specify the paper size and type?
Solution: Specifying the Paper Size and Type
  • When making copies on LTR-size paper after having continuously copied on paper smaller than LTR-size paper, the copies may be dirty. To prevent copies from being dirty, wait about 1 minute before making copies.
  • The paper in the multi-purpose feeder is fed prior to the paper in the cassette.
  • The settings changed in the Menu do not return automatically to the settings you set previously. Change to the previous settings again if necessary.
  • When making copies of a small size or heavy paper*, etc., the copy speed may be slightly slower than usual.
    *The paper type should be selected in the Menu.
  • If you intend to make a copy and print with a thermal transfer printer using the same sheet of paper, make the copy first. Failure to do so may make copies dirty or cause a paper jam.
  • When copying onto transparencies, remove each transparency from the output tray as it is output.
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
alfi819
  • 65 Answers
SOURCE: does the mfc 7420 scan legal size docs?
Yes. You could look at the printer specifications.
Posted on Mar 27, 2009
  • 16 Answers
SOURCE: HP Color Laserjet 2840 will not completely scan legal size docs
have you downloaded the scanfix that is own the HP support site?
Posted on May 22, 2009
SOURCE: cannot scan legal size document
You likely need to install the Brother Scanner Resolution Improvement Tool. The description of the download states:
"This tool will expand the maximum scanning resolution capability and allow you to scan legal size documents."
Here is a link for the Windows Vista download
Posted on Jun 08, 2010
Scan to pdf
Hi there, have you downloaded the latest scanner software from Brother and then do the scan from within the software interface. When you press the scan button, do you get the option to scan to and then the format that you want the document scanned. Here is a link to the scanner software from Brother. Downloads MFC 8860DN Others Brother
Good luck and I hope this helps.
Jun 25, 2014 | Brother MFC-8860DN Printer
How can you scan a legal size paper on this machine.
Put the document throught the ADF (Automatic document feeder) as opposed to on the scan bed.
Make sure you have legal paper in the tray and the tray is adjusted properly
Jan 06, 2011 | Brother MFC-7340 All-In-One Laser Printer
Have MFC 5890CN Brother. How can I scan legal documents?
To scan legal documents you need to set the scanner to legal. GO to Start menu / all programs / brother / scanner utility and set the size to legal.
Thanks,
Pat
May 11, 2010 | Brother MFC-5890cn Color Flatbed...
I can't get my printer to scan a legal size document, but have no problem with a letter size.
When you get your control panel for the document, you need to change the configuration document size. In mine, Legal comes right after Letter.
Carl
Jan 01, 2010 | Brother Office Equipment & Supplies
Cannot scan legal size documents. The scan goes through but it will only scan the letter size portion of the document and drops the rest of the text.
Nov 06, 2009 | Brother MFC 8840D All-In-One Laser Printer
Brother 9840CDW won't scan/fax legal size pages from glass or ADF
Is a setting in the printer.
Go to start >Brother> start center> on top go to configuration. then it will ask you for a password. use "access" for the password.
click on general setup and you'll see document scan at the bottom.
Change it from letter to legal and apply.
Voila!
Sep 02, 2009 | Brother MFC-9840CDW Laser Printer
How do i reset my scanner on the brother mfc-6490cw all-in-one printer/scannner/fax so i can scan in legal size documents? now i can only scan in letter size.
Launch scanning utility from computer instead of using the scan button on the Brother. Tha will give you more options. You also may need to configure the Brother software settings.
Aug 10, 2009 | Office Equipment & Supplies
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Scanning
One approach that works for me is to scan the document at high resolution and then shrink it afterwards. For some reason this seems to result in higher quality than scanning at the final (lower) resolution in many cases. For example I use ACDSee Photo Manager to scan or post process a scan from elsewhere. Within ACDSee there is an option in the jpg output (file save as) dialog for quality versus compression. I set this to default to the highest compression and resave the jpg or convert to jpg if the file did not start out that way. This generally shrinks the file by up to 2x or even 4x without any degradation that I can see. For example the screen capture below went from 39k to 18k after this step with no resolution change. If that is not enough I then perform a resize operation, for example 50% which would further reduce the file size down to a quarter of the input size (the dimensions in each direction would shrink by 50%. Even after shrinking, I find that files lookbetter than if they had simply been scanned at the final resolution.f611aa5.jpg
Dec 06, 2007 | Brother MFC-8860DN Printer
I can't Scan 8 1/2 by 14. It cuts the scan to that of a regular paper. I can fax by 8 1/2 by 14 and it comes out alright. how i do the set up. I used the set up in the scan but it did not help.
I also had problems scanning legal size documents with a Brother MFC-7440N. The documents would scan but would not come out complete. A large portion of the text would always be left out and only an image of the size of regular page size would come out. I knew it had to be something with the settings, so after experimenting with my MFC-7440N I came to the conclusion that I was not going to find the solution on the actual machine. I had a "Hunch" that I would find my solution by connecting the printer to my laptop computer and use the software that came with it. After a couple of minutes I was able to scan Legal Size documents in a breeze... I should of done this months ago. All scanned docs came out in full size.
So I took some screen shots to post them up here to let everyone know how to scan legal size documents since I noticed that people are having trouble just like I did. With this instructions you will also be able to scan any available size documents with a Brother MFC-7440N. I will also guide you step by step. After step 4 the remainder steps are OPTIONAL unless you need to change the color or picture file types. Okay, here we go!
Step 1.
Make sure your MFC-7440N is connected to your computer and the computer has the software installed that came with the printer.
Place the Legal Sized documents/papers that you want to scan on the Paper Feeder Scanner located on the most upper area of the machine.
Step 2. On your computer, go to START then to DEVICES and PRINTERS, or CONTROL PANEL then DEVICES and PRINTERS. Locate the icon of your MFC-7440N. If its not your DEFAULT printer make it the default one. Then RIGHT Click on the icon. A menu will pop open. Locate START SCAN and click it.
Step 3. A small window will open that will give you various options to scan a multitude of sizes and different settings. Locate where it says SOURCE. The default setting might be FLATBED meaning the flatbed scanner of your machine. Click the drop down menu and select FEEDER. By selecting the feeder option your computer will tell your machine to use the automatic paper scanner located on the most upper area of your machine.
Step 4. Locate PAPER SIZE. Click on the drop down menu and then select Legal 8.5 x 14 inches (216 x 356mm).
If your documents are already located in the feeder you can now go ahead and click SCAN and your documents will begin to scan.
Your scanned documents will be saved in a file folder in your computer and that file will pop open for your convenience once all documents are scanned.
If you need to change COLOR or Black and White setting plus Picture File Types such as Jpeg or Tiff just click on their respective drop down menu before clicking SCAN.Here are some pictures to help me illustrate it.
I hope you find this helpful.
Thank You!
Visit me at:
Facebook.com/BestCreditRepairManualor at
BestCreditRepairManual.com 92c85b21-a89d-4f9a-bf67-a96f103f2c15.jpeg 6adfe3bc-45ef-4e80-a6b2-7b825e659868.jpeg da5aa6de-6531-4fb6-9f91-3a1b503ac89c.jpeg 36e97075-1229-4d28-b14c-e7371ad26589.jpeg 15d2f41b-30e0-42cd-9e6d-663e9bb17a3c.jpeg 6d240b8f-2360-4094-8d6b-0c8cd404332c.jpeg 4203c1e5-8b35-4dc9-a802-65652251f028.jpeg
Oct 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8860DN All-In-One Laser Printer Logo
270 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
