Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Belkin N router will not let Mac notebook connect now that N/G/B is enabled
Until recently, I was running my router in G-mode only (I did not have an N adapter) which worked fine with my wired PC, PC laptop, Mac notebook (not sure what model), and PS3.
I just installed an expresscard N adapter in my PC laptop (which works great), but now the Mac will not connect to the router. It can see it in the wireless networks available.
I also changed the channel from 6 to 7 in the router config.
I realize from browsing multiple sites that Belkim N does not usually work with Macs, but think it`s odd that it worked in G-only, but not in mixed.
The router did not advise that it needed a firmware update on May 26/08 when I last accessed Admin config.
Any thoughts would be great!
  • why_14 May 11, 2010
    There were some intercompatibility issues with the Macbook's airport drivers, what OS are you running? if you are running 10.5 have you downloaded the 10.5.2 update?
  • 306 Answers
The router does not care what brand of computer that wants access, only a MAC address. If you can see it in the wireless scan then you have a configuration setting to resolve. Steve Medley
Posted on Nov 07, 2008
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
I have this belkin and I want only myself to use this router, how do I blocked it from others?
Hi there.
I'm sure you want to secure your wireless network so only you can access it. There are many ways in doing this But first you have to change the router's default password to this You can enable the wireless encryption so you will be prompted to type a network password before connecting to your network. Lastly you can enable MAC filtering.
To enable wireless security click the link below: To enable the MAC filtering click this link below:
Apr 05, 2011 | Belkin (F5D6230-3) Wireless Router
Every time i secure the router the wpa/wep isnt compatible with my daughters laptop.....not too sure what do
Does your daughter have a very old laptop? Some older wireless cards do not support wpa/wep. You can still get her a USB wireless adapter and use that to connect to the router.
Mar 01, 2011 | Belkin F5D7234-4 Router
Setting up a belkin n wireless router. How do I
You have to go into the setup for the router. Most default to the IP address. You would type that address into your internet browser and hit enter. Then you will be asked for a name and password. If you have your belkin manual it will tell you the default name and password. Once in the settings you can change the password. You can also turn off SSID broadcasting, enable the highest level of security that your particular router supports in conjunction with your computer and enable MAC authentication. If you enable MAC authentication you have to type in the MAC address for each device you wish to have access to the router.
Nov 07, 2009 | Belkin Computers & Internet
Why does my belkin g wireless modem router f5d7634 always disconnect every hour? i already turned the firewall off and yet it still disconnects from the internet. the globe led does not turn off but i...
You said that the Internet connection is dropping. It is a modem *** router.
If there is any MTU settings , then reduce the MTU.
For example If MTU is 1500 then reduce it to 1400.
Otherwise you will need to upgrade the Firmware of the router.
Click Here for more info about the networking
Oct 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
Oct 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless connection problem. Computer does not recognize router
if you are not able to connect wirelessly it is possible that the mac address filter is enabled in the router / check this page for help.
Jul 16, 2009 | Belkin (F5D5231-4) Router
Cant connect to the Internet through a Belkin router
May in your router MAC security is enabled.Which prompt your computer to conect .
first access your router with
Type username as "admin" and password is "admin" or blank or "password"
then go to wi fi security then mac security then add your computers MAC addreses in allow list.
U can knnow your computer MAC addreses with following command.
type in start menu -> RUN -> "ipconfig /all"
u can see physical addrses it is MAC addreses.
Jun 07, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
149 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
