I'm trying to install printshop2.0 but the only problem is that my computer has no DVD-ROM drive, is there any other way to install this/
    Master:
  • 388 Answers
You can use an external dvd player.
Posted on Oct 07, 2010
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
Hello My Hp pavilion dv2000 is ready for vista but nowadays i install windows 7 home edition and after install my cd/dvd rom icon don't show in my computer. i try to solve this by removing disk drive...
Go to Control Panel-->Administrative Tools-->Computer Management
Your CD/DVD rom would be listed there... Just right click on the DVD rom and select"Change drive letter and path". Then select "Add" and change the drive letter..
Oct 06, 2010 | Computers & Internet
Asus e818a3t is recognized as a DVD-ROM only. I can no longer write CDs after my Windows 7 Pro 64-bit install. Windows says the driver is installed and everything is working properly. Obviously not!
Hello there,
Try this trick,
1. Go to Hardware Profile and Remove your Asus ROM profile.
2. Shutdown your Machine -
3. Remove the Asus ROM from your Sata Connector.
4. Turn your Computer ON without that ROM
5. Shutdown it again, and Reconnect your ROM to those Sata connectors
6. Comment back here if still not working. :)
Cheers!
Aug 20, 2010 | ASUS DVD E818A3T - Disk drive - DVD-ROM -...
I had this problem for about 5 months my lg dvd rom dint read dvds . i installed ffirmware and tried to update it but there was erreor and now dvd drive doesnt even work. no green blinking light. when i...
This is the inherent risk in updating firmware to optical drives.
Buy a new drive, power down the PC, install it and reboot the PC. If it is and IDE drive, or a SATA for that matter, before you buy a new drive make sure to disconnect and reconnect both ends of the cable prior to replacing it, just to be sure it wasn't an accidentally dislodged cable causing the problem.
Dec 28, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Game will not install at all
You can try to not double click on your dvd drive, because when you double click, your computer tries to run "autorun", you should browse your files from explorer and try to do one click to your dvd or cd drive, than run your setup exe, if its still freezing, try that cd or dvd at another computer, if it acts same,you can be sure your game dvd is broken. Go to your seller.
Feb 21, 2009 | Enlight Interactive Scrapland for Windows
Installing a new DVD drive
Step1::Ground yourself by first touching a metal object or wearing an anti-static wrist strap. This helps protect your computer's internal
components from damage due to static.
Step2::Shut down your computer and unplug it to protect yourself from electric shock.
Step3::Open your computer's case using the door on the side or follow the manufacturer's directions for your desktop.
Step4::Install the DVD ROM on its own IDE channel. Since a DVD ROM uses a good bit of memory, it should also be the master drive. Set your old
CD ROM or secondary DVD ROM drive to "slave" and set the new DVD rom drive to "master."
Step5::Slide the new DVD ROM in the free 5 1/4-inch bay and use clips or screw into place if necessary, then use the data cable that came with
the DVD drive to connect your new drive. Plug in the power cable as well.
Step6::Replace the cover on your computer, plug it back in and boot it up. If you have Windows XP, it should automatically detect and attempt
to install the new DVD ROM drive. If it doesn't, use the installation disk that came with your DVD ROM.
Nov 27, 2008 | Acer Computers & Internet
Need to instal cd/dvd rom into Dell lattitude laptop
You will need to connect to cables.1 is from the power supply and one is from motherboard.Just connect both to the ROM and start the computer.Windows will automatically install the drivers for your ROM..
Nov 09, 2008 | Dell (6T980-A01) CD-ROM Drive
Where can i buy a dvd rom and how to install it
You can buy a DVD rom from any regular electronics and computer store. just go there and ask for a DVD rom
Sep 24, 2008 | Dell Compact Disc Reader CDR-1900 CD-ROM...
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
A DVD-ROM problem
Find a technician who can do it for you - or if you are conversant with computers you get an eternal dvd rom Drive and use it. Have you tried the floppy drive if your computer has any? or the flash disk?
please try one these options.
Dec 31, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
