Question about Hitachi Televison & Video
The Hitachi 22 inch LCD TV/DVD combi, model no. L22DP04UA, has a USB imput socket which I wish to use for viewing photo files off a memory stick. In the slide show mode a blank screen appears between each slide with an annoying turning icon in the centre of the screen. Is there a way of changing the slide show settings to eliminate the gap between each successive photo, ie: fade out/in etc. I cannot see anything in the user manual about this. Thank you.
    Top Expert:
  • Hitachi Master
  • 23,148 Answers
Each photo must be read separately unlike your PC.
Posted on Jun 19, 2017
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
SOURCE: Tevion 19 LCD TV Model Number 1961HDT
eh, that should be 0871 663 1540
Posted on Jun 25, 2008
futurework
  • 70 Answers
SOURCE: 23 inch Ilo LCD Tv Model # v23dlwx
I just repaired this model and the power supply board had 2 bad 22 uf 50 v cap's. I replaced them and the unit is working fine now. Your unit will need to be repaired by a technician.
Posted on Mar 23, 2009
  • 90 Answers
SOURCE: dell 42" plazma tv
turn the tv with the rear cover facing you. power on the tv, look into the grills on the rear cover. If you happen to see 3 green lights together on the mainboard, you have communication signal. Otherwise, its the mainboard. If u get all 3, then its your Y main board and probably a lower or upper buffer, depending on where burn is located on panel board.
Posted on Mar 24, 2009
SOURCE: I WANT TO VIEW PHOTO'S FROM CD OR MEMORY STICK ON MY TV
If you have a Play station 3 game console it has that capability.
or some PCs have vidio outputs that you can hook to your TV.
Posted on Sep 18, 2009
Testimonial: "Thanks for that I was hoping there would be some way of just plugging in a memory stick, it is a bit of a nuisance using the lap top."
Model dc164. How do I view photos without memory card?
That model uses a DVDR/RW type discs plus a memory card (SD, MMC or Sony Memory Sticks). To view photos from the disc simply go into view mode and use the joystick to move to the image you want to view. If you want to transfer images you need the USB cable that came with it and the original software to transfer images from the disc. While capturing video you can snap images but only to a memory card/stick. No card/stick while shooting video, then nothing was captured and the only way you can get any images is transferring a frame(s) from the video using the USB cable and their included software.
Here are links to the manufacturer website where you can still download the software that came with that model and a second link to view/save the manual in PDF format. Information to read in the manual are on pages 95 & 108.
Support DVD Camcorders SCDC164 Samsung Digital Camcorders
http://downloadcenter.samsung.com/content/UM/200704/20070412144931140_AD68-00993F_us_spa_0119.pdf
Nov 25, 2015 | Samsung Cameras
I have an Hitachi (L22DG07U) 22 Inch LED LCD DVD Combi TV that will not turn on, the lights flash between red and blue but no picture.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 19, 2014 | Hitachi Televison & Video
UUuuhh how do i send photos
You TV will not be able to send photos, as it has limited functions and is not set to work as a full computer. You however can view (receive photos for viewing on the tv screen.) If your TV has a USB port, you can transfer your photos from your computer or camera to a thumb drive (A USB memory storage stick) which you then can plug into the USB port on your tv.
There are other ways to send photos to your tv, but there is not space here to get into how to do that.
Nov 05, 2014 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
What's your problem?how do i view pictures from my panasonic lumix camera on my sony bravia klm ex500 tv
You need to copy the photos from your camera to an USB memory stick and then plug the USB memory stick into the USB port on the TV.
Then press Menu button on your remote and select Photo and it will then connect the USB memory stick and display your photos.
Nov 03, 2012 | Cameras
VENTURER PLV91217S52 22" LCD TV Hi does
Good day!
Unfortunately that TV Doesn't play media from U.S.B device.
This is the great features of that TV.
  • Free view built-in-- This TV includes a digital tuner which allows you to watch u p to 40 digital Free view TV channels with no monthly subscription or contract required.
  • Built-in DVD player--Your TV have a DVD player.
  • 720p H.D ready-----H.D Ready TV sets have a minimum horizontal resolution of 720 lines which means that they are capable of displaying high definition TV signals like play-station3
  • 1 High Bandwidth Digital Multimedia Interface - highest quality digital connection.
Thank you very much.
Apr 21, 2011 | Venturer PLV36220S1 22 in. LCD TV
Phillips 42pfl7432d/37 has sound and ambit lights but no pic. What can I do to resolve this?
Experience the superior picture quality of this excellent Flat TV with LCD technology and Pixel Plus. It's packed into a stunning design that will complement your interior. Share music and photos via the built-in USB. The built-in HDTV tuner that receives and displays terrestrial ATSC and unscrambled cable signals. The USB connector allows access to multimedia jpg, mp3 and alb files of most USB-sticks and most digital cameras (USB 1.1 memory-class device). Plug the USB into the slot at the side of the TV and access your photos or music files. This makes you easily viewing and sharing your photos and music.
The cost was great especially with no intrest for 12 months. The TV is awsome in just 480p mode. Watching movies is more enjoyable,and the Nintendo Wii looks Great with component cables.Cant wait to get my PS3 to get the full use of the TV with the bluray games and movies with the HDMI cable. Just with the regular yellow video cable I get great picture from my Directv.I have my HD programming on order to enhance my viewing pleasure.This tv rivals it's 1080p counterpart.Overall great TV
http://www.seekic.com/ and http://www.chinaicmart.com/ you can on the regular talk about these issues.
Dec 10, 2010 | Philips 42PFL5332D 42 in. LCD Television
I need the code for polaroid tv with asda remote control model no:urc20-d1f
I just bought a Polaroid 22 inch LCD DVD Combi,, I struggled for hours trying to find a code online,, and eventually researched that my Polaroid TV is made by Phillips,, I entered a Phillips 4 digit code (0081) and it worked.. I also found this link very helpful,, I used the 4 digit code routine. http://www.rtv.co.uk/remote_codes_for_sky_dig_remote.htm
Oct 14, 2010 | Televison & Video
Sep 18, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Ii own a minteck lcd dvd combo
I have a Mintek lcd/dvd combo which when turned on , comes on with picture and sound but the picture goes off in about one second. I removed the back and can see that the back lighting is going off. I measured some voltages at a terminal strip that i believe provider the back lighting for the set. The results seemed to be normal to me. Can you suggest where I should look further.
Nov 24, 2007 | Philips 42PF7220A 42 in. Plasma Television
Open Questions:
Televison & Video Logo
123 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
