Question about Frigidaire Kitchen Ranges
Frigidaire freezer FFU14f is in demo mode and I can't find how to get it out..
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
TURN DEMO MODE OFF
Thank you for your post, friend!
In order to take your Frigidaire refrigerator out demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. If you could follow up with a post I would greatly appreciate it. -Matt
Feb 15, 2015 | Frigidaire Refrigerators
How do I turn off demo mode on my frigidaire refrigerator model# FRT18B5JW?
Hello friend, thank you for your inquiry!
I understand that your Frigidaire refrigerator has been plugged in for 24 hours and is still not cooling. I would recommend you adjust the setting to a colder setting to see if that would jump start the compressor. I have reviewed your appliance and I was unable to locate a demo mode for your appliance. You can also attempt to perform a reset which is unplugging the appliance for roughly ten minutes and then plugging it in. I hope this is helpful. -Matt
Sep 13, 2014 | Frigidaire Refrigerators
How do I turn demo mode off on FGHS2631SS Frigidaire?
Are you sure you have the right model #? Your refrigerator's model number may vary by type. The model number of a top freezer refrigerator can be seen along the upper left side wall of the fresh food compartment and is visible when the door is opened. The model number of a french door and side-by-side refrigerator can be seen along the upper right side of the fresh food compartment and is visible when the door is opened. model-number-refrigerators.png
Sep 10, 2014 | Refrigerators
How to put refrigerator into demo mode?
Hello friend, that's a great question!
In order to put your Frigidaire refrigerator FGHB2866PF into demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. Hope this information helps. -Matt
Jul 21, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Frigidaire
If it is showing "OFF" then the unit is in demo mode. To remove this press the up or down arrow three times as fast as possible (within 2 seconds). This will start the compressor. I hope this helps.
Jan 06, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Error Codes OF on an upright freezer
Which model Kenmore freezer do you have? For the Kenmore 253.28462801, made by Frigidaire, the OF code means that the freezer is in Demo mode. You need to turn off the freezer by pressing the UP arrow until the unit reads 10. Pressing the UP arrow twice more within 2 seconds brings the "0F" code.
Press the Down arrow twice within 2 seconds to turn on the freezer. (The display will read -10.) Use the arrows to set the desired freezer temperature.
If your freezer was made by Frigidaire, you can usually find the manual on their support site: http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Other Kenmore appliance manuals are often available from Manage My Life, http://www.managemylife.com/mmh/owner_manuals . Some paper copies of the manuals can be purchased from the Sears Parts Direct, http://www.searspartsdirect/ . Note: you will need Adobe Reader or a similar program to read the manual from Frigidaire or Manage My Life.
I hope this helps.
Aug 15, 2013 | Washing Machines
Can't set the temp it blinks 0
If "0F 0F" appears on the display, the refrigerator is in DEMO MODE. To exit Demo Mode for controls on the outside of door, Press and Hold the Energy Saver and Adjust Freezer buttons at the same time for 3 seconds. To exit Demo Mode for controls inside the Fresh Food Compartment, Press and Hold the Ice Off and Freezer buttons at the same time for 3 seconds. You will hear a beep and "0F 0F" will no longer be displayed. Adjust Refrigerator and Freezer temperature to the desired settings. Allow 24 hours for temperatures to stabilize.
Feb 04, 2013 | Refrigerators
Kitchen Ranges Logo
154 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
