Question about Microsoft Windows XP Professional
XP Professional Edition Error windows root>\system32\hal.dll CD will not allow me to repair file.
    Problem Solver:
  • 10 Answers
Most likely not a XP driver, Search online.
Recommend Purchase of auto driver installer
Posted on Oct 07, 2010
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
How to solve this problem <windows root>\system32\hal.dll.
Hi
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
1.Insert and boot from your WindowsXP CD.
2.At the first R=Repair option, press the R key
3.Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4.Type bootcfg /list to show the current entries in the BOOT.INI file
5.Type bootcfg /rebuild to repair it
6 Take out the CD ROM and type exit
OR
Better solution: This seems to always work
expand x:\i386\hal.dl_ y:\windows\system32\ X= cd rom drive letter
Thanks and Regards Aboobacker S
Sep 23, 2010 | Microsoft Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Sep 05, 2009 | Microsoft Windows XP Home Edition
Windows error ... \system32\hal.dll. Please re-install a copy of the above file!
Use the recovery disks that came with your computer to do a repair installation. Put the disk in your cd / and or dvd rom, restart computer and select repair installation from the prompt.
May 02, 2009 | Computers & Internet
Lode needed dlls for kernel
Use the ERD disk and repair the installation. Choose to replace all files, and then replace only the Hal.dll and Ntoskrnl.exe files.
If you can start another installation of Windows NT on the same computer, you can expand the correct Hal.dll and Ntoskrnl.exe files from the Windows NT CD-ROM. To do so, follow these steps:
  1. Boot to the working version of Windows NT.
  2. Start a command prompt.
  3. Change to the CD-ROM drive.
  4. Change to the appropriate folder on the CD-ROM (for example, I386 for Intel-based computers).
  5. Type expand hal.dl_ <systemroot>\system32 where <systemroot> is the path of the non-functioning Windows NT folder.
  6. Type expand ntoskrnl.ex_ <systemroot>\system32.
  7. Restart the computer into the other Windows NT installation.
Mar 27, 2009 | Microsoft Windows XP Professional
Hal.dll file missing, can't boot from xp disc as error states hard drive cannot be detected
Issue : Blue screen - Missing HAL.DLL error message
Solution :
1) Insert your windows XP CD into your CD/DVD drive.
2) Restart your computer.
3) Press the F12 key to access the one time boot menu.
4) Select Onboard or USB CD-ROM Drive.
Press any key when prompted.
5) The Windows XP Setup will launch.
6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page.
7) bootcfg /rebuild
8) Enter Y and press enter
9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition.
10) Type /fastdetect
11) Type Exit
Nov 15, 2008 | Computers & Internet
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Microsoft Windows XP Professional Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
