Question about Candy A8001 Dishwasher
The r button is flashing - Candy A8001 Dishwasher
I can't find my GPX TV remote code for my dish network.
You may be able to get the code out of your Dish remote. Hold the "TV" button at the top down until all the lights across the top go on solid, then release the TV button and wait for it to flash. Right after it flashes, press the "#" key twice, then count the flashes of the TV button. For example, if the code was 232, the TV button will "flash flash pause flash flash flash pause flash flash".
Jun 17, 2016 | Televison & Video
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Bdv e3100 region free
try this
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 1891 (this sets key 1 - the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 2552 (this sets key 2 - the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 0953 (this sets key 3 - the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 2214 (this sets key 4 - the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 0795 (this sets key 5 - the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Oct 16, 2013 | Sony BDV-E3100 5.1 Channel 3D Blu-ray Disc...
Hi Machine will no start..At first all lights flashing and now just start and reset button flashing.. Start button flashes 3 times reset button flashes 5 times. Can you help. Cheers
I have a zanussi zwf1432w aquacycle.
Hi Machine will no start.Starts to fill,Stops and goes straight to drain.There is no blockages in filter or pipes,Have checked all,Even pipe from drum to filter.
Can you help.
Cheers
Apr 05, 2011 | Washing Machines
How to unlock region free on U.S sony bdp-s350
Sony BDP S350 bluray - unlocking to region free Yes, it is possible, but you'll need a programmable remote - most use the "one for 3/4/6/all". You can hack it by using the same code as for the bdp-s350. Follow the instructions exactly and it should work - mine does.
Programming the 7040 OneforAll remote to enable region free playback of DVD's on the Sony BDP-S350 Quote: 1. Press DVD 2. Hold the magic button until the DVD button flashes twice. 3. Press 0533 4. Hold the magic button until the DVD button flashes twice. 5. Press 994 6. Press Magic Key (don't hold) 7. Press 1891 (this sets key 1 - the DVD button flashes twice) 8. Hold the magic button until the DVD button flashes twice. 9. Press 994 10. Press Magic Key (don't hold) 11. Press 2552 (this sets key 2 - the DVD button flashes twice) 12. Hold the magic button until the DVD button flashes twice. 13. Press 994 14. Press Magic Key (don't hold) 15. Press 0953 (this sets key 3 - the DVD button flashes twice) 16. Hold the magic button until the DVD button flashes twice. 17. Press 994 18. Press Magic Key (don't hold) 19. Press 2214 (this sets key 4 - the DVD button flashes twice) 20. Hold the magic button until the DVD button flashes twice. . 21. Press 994 22. Press Magic Key (don't hold) 23. Press 0795 (this sets key 5 - the DVD button flashes twice) Done - the remote is now programmed and ready to use Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed 2. Make sure there isn't a disc in the machine. 3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing) 4. Put the player back into standby with the Sony remote 5. That's it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh Good luck
Dec 02, 2010 | Sony BDP-S350 Blu-Ray Player
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
How to set to 24hr mode for timex 1440 sports
Setting My Timex 1440 Sports Watch (4-button)
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds)
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes ( now it can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
Feb 04, 2010 | Timex 1440 Nylon watch
LOOKING FOR HACK CODE AND REMOTE CONTROL MODEL NUMBER I SHOULD USE TO DO THIS
one for all rc 7652 works for this as do many others.
1. Press DVD
3. Press 000533
5. Press 994
7. Press 001891 (this sets key 1 – the DVD button flashes twice)
9. Press 994
11. Press 002552 (this sets key 2 – the DVD button flashes twice)
13. Press 994
15. Press 000953 (this sets key 3 – the DVD button flashes twice)
17. Press 994
19. Press 002214 (this sets key 4 – the DVD button flashes twice)
21. Press 994
23. Press 000795 (this sets key 5 – the DVD button flashes twice)
5. That’s it, the next time you turn on the player it will be region free for DVD playback
I personally dropped the 00 that are marked red and it worked for me but it depends on model of one for all remote.
Jan 31, 2010 | Sony BDP-S360 DVD Player
Flash
Set jog dial on Auto (green mark) and press flash button (left button of navigation buttons) to set flash mode i-e auto, synchro, off etc.
Below image shows flash button in navigation buttons.
Mar 27, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Dishwashers Logo
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
