Question about Broan-NuTone CV353 Central Vacuum
The motor is not working all the time. Sometimes takes an hour or so before it kicks in. I unplug the unit and plug back in along with re-set button but does not seem to matter
  • 171 Answers
That is an older unit I am guessing and I would suspect that it is the heat sensor that is shutting it off as it is probably shot. Can you tell me the model and approx. year it was made/purchased. thanks
Posted on Oct 07, 2010
My brush stop working
Barring any electrical failure or loose plug the most common cause for the vacuum brush to stop turning is belt clogged with debris or string.
Unplug the unit and check the brush for string or debris (Hair) wrapped around the pully on either end. Clear this and check the belt to make sure it has not broken, stripped or simply slipped off. Usually the bottom plate is held on with just a few screws. Easy to remove and check Belt slipped off or stripped replace. Belt slipped off you can sometimes put back on and be vacuuming in no time.
Anything wrapped around the spindle a pair of needle nose pliers comes in real handy here. If you have snagged a rug, sheet or sock etc.. check the manual for a reset button. Some vacuums have this and all it takes is clearing the chute then resetting the switch. Good luck hope this helps!
Apr 03, 2014 | Vacuums
Hoover S3765
If you light and nozzle motor both go off at the same time, you might have a bad power cord. Mine had this problem which I could verify by jiggling/twisting the cord near the strain relief on the nozzle. It would go on and off as I did this. The cord is cheap to replace, around $13 for the part shipped. Part number is 59134072.
May 30, 2012 | Hoover S3765-040 WindTunnel Bagless...
Vacuum cleaner does not work
most upright vaccums have a reset button at lower rear area of the vaccum. operates similar to gfi plug reset, push button back in usually with small screwdriver. is your debris bag to full? power brush jammed with debris? hose plugged? this will cause motor to over heat and in turn kick out reset button. always unplug power cord before putting fingers in areas where moving parts are!!
Jan 01, 2012 | Bissell Vacuums
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I need to replace the electric cord and need to know how to take out the old one a replace it.
First remove the handle from the machine and remove the plastic trim around the switch button. There are two screws holding the trim piece in place. Next insert a small flat screwdriver into the small slot on the trim piece are pry up to pop it off. There is a cover over the bottom of the cord where it plugs into the side of the motor unit. Remove the screw holding it in place and push it gently forward to disengage the tab along the back edge. The cord plug then pulls straight out to remove the cord. Push the new cord into the motor unit, and re-install the cord cover. Hook the bottom of the cord cover into the machine first, then insert the grommet on the cord into the opening at the upper rear of the cover. Push against the rear edge of the cover with a flat screwdriver to snap it back in place and replace the screw. Lastly, the switch trim plate can be replaced.
Apr 19, 2011 | Kirby G4 Bagged Upright Vacuum
I have replaced the circuit board twice on my hayden 2400 and after working for 24 hours the circuit board then fails, with no signs of it tripping. Everything is wired in correctly the supplier is unsure...
Disconnect the wiring from the unit, and go back and plug in your hose.
Get a volt tester and test the voltage coming from the lines at the machine. It should read 0 volts. Check both AC and DC voltage.
Also, check the same setup if you have a security system. Arm the security system (or have someone do it for you) and test the voltage at the line again. Again it should read 0.
If both come up 0 volts, the security and the hose I mean, unplug the hose and try one more time again AC and DC volts.
The only other thing i could see it being is a problem with the motor, if the unit is 7-10 years or more, it may need a set of motor brushes for the motor.
Let me know how this goes.
Mark
Nov 08, 2010 | Hayden Industries SuperVac 2400 Central...
The vacuum stopped running and won't turn back on?
While there's no reset button it's not uncommon for the internal thermal switch to trip to an "open" position. This internal, no-access-switch opens when the motor gets hot, it protects the motor from overheating to the point of failure. Bissell's website states that if the thermal switch is tripped let the vacuumm sit for a half hour and then it try it again.
If it doesn't work you might then try Tech610's suggestions.
Dec 08, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Problem starting
This can happen if you have an intermittent short in your cord. Try plugging it in and then wiggling the cord around where it goes into the body of the vacuum with the switch set to "on." (If you're not sure whether it's on or off, just click it back and forth occasionally.)
If the motor kicks on there's a short, which usually requires a cord replacement. If that's the case, it's a relatively simple fix for most dyson models.
If not, you could have a short in your switch or somewhere else in the electrical system of the machine.
-R
Aug 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Electrolux Centralux Vacuum
If the light came on when you plugged it in, then you have power to the unit. You can take a coin and short across the two pins where the small, low voltage wires connect to the unit. Just remove the two wires, they should just pull off, and touch the two pins together with the coin. The unit should come on. If it doesn't, and the light is on, you may have a bad motor or a bad relay on the board inside the unit. Another thing to check is the filter. It has to be installed properly or the unit will not run. The top of the filter depresses a switch so that the unit cannot be operated without a filter in place. Good Luck!
Jul 20, 2008 | Electrolux Centralux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113669&thid=657359
Posted by Brucebob on Jun 09, 2008
I have an Electrolux Centralux. When I plug the hose in at one of the wall outlets the motor will not start. If I go to the motor and slap the unit it will start.....then...it will not stop unless I unplug the power cord to the motor.
If I plug the power cord back in, the unit will not restart until I slap the motor unit again. The unit has only been used 20 - 30 times.
Any suggestions? Thanks, Bruce
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have a bad inlet or household outlet; try all the inlets in the house too. But it sounds to me that your carbon brushes are dirty and need cleaning or replacing would be my 1st suggestion. Take a good wire brushes or pipe cleaner to clean the inside of the carbon brushes if they stick then replace them. So if the unit has only been used 20 to 30 times I would suggest some one to come and look @ it who did the install because it is still under a factory warranty and if you start messing with things you will void the factory warranty on the motor. And then if it is the motor for some reason then the factory or vendor will eat the cost of the repair. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Electrolux Centralux Vacuum
Broan-NuTone CV353 Central Vacuum Logo
90 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
