Question about Philips DVDR985 DVD Recorder
My Philips DVD985 DVD recorder gives error codes AB FFCF2F and AB F0C2EF. What does this mean? Is it a disk error or a player error?
  • 476 Answers
SOURCE: Philips Hard Disk/DVD Recorder Model DVDR3370H/97
There was a compatibility issue with this model. Philips released a software update for this model.
Follow this link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=DVD_HOME_THEATER_CA&sct=DVD_HARDDISK_RECORDERS_SU&session=20080216151231_81.77.115.133&grp=HOME_ENTERTAINMENT_GR&ctn=DVDR3380/05&mid=Link_Software&hlt=Link_Software
Read and follow the instructions CAREFULLY.
Posted on Feb 16, 2008
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
rizla
  • 1463 Answers
SOURCE: Region Code Error for Philips DVP3256
hi
you can try this
>Go to Setup.
>Select Preference Page.
>Press 1, 3, 8, 9, 3, 1 on the Philips DVP3986 DVD Player remote.
>Press the up/down key to select "0" which makes it region free.
>Press ok and exit setup.
riz.
Posted on Feb 24, 2009
  • 50 Answers
SOURCE: WRONG Region error . Philips DVD65K
Regioncode for this player is:
1) Turn on the player
2) Open the tray.
3) Press 9 9 9 9 on the remote, you can do it rather slowly.
4) Press what region you want, 0 is regionfree.
Jay
Posted on May 23, 2009
rulds2008
  • 3866 Answers
SOURCE: Philips dvd985 recorder -failed diagnostic - error DB 7FC6 IBF6
This is proabbaly a motor inside that went bad these motors are not something that cannot be replaced so you can have a fully functional recorder you just got to find the right motoe I would call phillips if I where you to see if they would replace the motor and sale you one.
Posted on May 25, 2009
My philips dvdr1000 shows only ab f092as when i am power on
The meaning of specific error codes is known only to Philips themselves, but 'AB' errors are to do with the analogue board circuitry and unfortunately this signals that the machine may require a factory repair. However you have nothing to lose by performing a firmware upgrade, which cured the problem for some.
Make sure you use the correct firmware, depending on whether your machine is a Mk I or II. Note that ff9o is the only firmware you can use for the former.
Firmware upgrade procedure
Jun 10, 2012 | Philips DVDR1000 DVD Recorder
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Error message e4 54040990
It may mean that the disk is no longer usable due to scratches or other over-use reasons. If a new disk, it may mean you're using the wrong brand. This machine works on recommended brands, and the brand of DVD+RW that has proven to be workable on this device, and that I use with no problems, is VERBATIM. Hope this helps you solve what's wrong.
Mar 22, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
May 25, 2009 | Philips DVDR985 DVD Recorder
Place a dvd in and comes up disk error, and this is also a clean disk
have you tried using a lens cleaning disk, the laser optics might be fouled up, also check your disk again for fingerprints, as that can also give out a disk error
Dec 24, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cant play philips dvdr3430v recorded discs on another dvd player or pc
the only solution to play your recorded disk on other DVD-players to "Finalise" the disk, it means you will be not able to record any other thing on that disk. This means you "close" your disk, furter recording will be not possible on that disk. I tried, it works. PC also will recognise that disk. You will find not the mormal "VIDEO_TS" and "AUDIO_TS" directories on the disk, but players will play it.
Have Fun!
Oct 29, 2008 | Philips Televison & Video
Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Sep 26, 2008 | Philips DVDR615 DVD Player
I cant record DVD's
If you mean burn a movie from the HDD to a DVD. It will only let you do this once.
Dec 30, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Power on no response
Here is the link to the manual if you need it; http://www.p4c.philips.com/files/d/dvdr9... best i could come up with is: unplug machine, then plug it back in while holding down "open/close" and "stop" (Page 49) run through the diagnostics as explained on page 51. This link below gives you available drivers and updates, try updating/reinstalling the driver just in case it is a software issue; http://www.p4c.philips.com/cgi-bin/dcbin... If you still have no luck, please post again. Hope this helps :)
Mar 17, 2007 | Philips DVDR980 DVD Recorder
Philips DVDR985 DVD Recorder Logo
244 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
