Question about Broan-NuTone CV350 Performance Bagged Central System Vacuum
I have the Nutone 353 central vacuum. The last few times we have used it motor has shut down and then will come back up after an hour or so. Re-set switch does not seem to matter
  • 4 Answers
This is typical of a motor going bad. As it heats up it shuts down all by itself, no sensors other than the mini breaker. The intervals will get shorter and maybe the minibreaker will pop. Your options are to replace the motor or the motor brushes if the motor is not past 800 hours of use. Your model is older so replacing the motor will be your best bet. It is not that difficult. The motor and instructions are available here builtinvacuum.com/help/nutone.html.
Posted on Oct 11, 2010
Go to beam.com and enter zip code to find closest dealer. They are great at service and repair and most will provide you with info and parts to fix it yourself as well.
Posted on Oct 08, 2010
  • 171 Answers
I would try emptying it out and also cleaning any filters you have access to at the same time. It is usually a sensor for heat that stops the machine and if it is getting full or has plugged filters it will get hot fast cool down and then it will do it all again . Hope this helps you. Good luck
Posted on Oct 07, 2010
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
Vacuum shots down after a short time, restarts but runs only a short time
yes that unit has 2 sensors 1 on the motor and 1 on the relay board 1 of them is bad which is making the vacuum shut its like a heat sensors its malfuctioning it shuts the unit down
Feb 17, 2011 | Broan-NuTone VX550 Bagged Central System...
Nutone Model CV353; runs for several minutes and then shuts off. After a couple of hours I can turn on again, but again only last a couple of minutes. Possible relay problem?
Check the filter. If it's dirty, thoroughly rinse it in cool water, then let it thoroughly dry before using. If you don't have an extra filter to use during this time, you should get one.
It could also be a clogged hose or pipe. These would cause the motor to overheat, thus shutting off. Check hose at end for suction. If weak or nonexistent, detach hose and try dropping a penny or dime, or marble, down the hose. If it comes out the end, the hose is probably clear. If this is the case, you need to check other outlets.
Dec 12, 2010 | Broan-NuTone CV353 Central Vacuum
Nutone central vac shuts down after a few minutes of use
this is a very common problem.
If the unit is less than 5 years old and you have your bill of sale it will be covered by warranty. Although one of my customers said that there is a recall on the motor in this unit. That is totally unverified. However, if it is still under warranty, contacting broan/nutone will give you the closest warranty depot, or they may just deal with you directly.
I do recommend that both the motor and the PC board inside be changed.
Good luck,
Mark
Nov 07, 2010 | Broan-NuTone VX475 Bagged Central System...
The motor is not working all the time. Sometimes takes an hour or so before it kicks in. I unplug the unit and plug back in along with re-set button but does not seem to matter
that is an older unit I am guessing and I would suspect that it is the heat sensor that is shutting it off as it is probably shot. Can you tell me the model and approx. year it was made/purchased. thanks
Oct 07, 2010 | Broan-NuTone CV353 Central Vacuum
Nutone cv353 unable to stop
the parts are available. go to:
NuTone Customer Service
Email or Call 888-336-3948
Hours: M-F 8:30 am - 5 pm EST
please rate my answer as a fixya!
Feb 26, 2009 | Broan-NuTone CV353 Central Vacuum
Broken Nutone central vacuum unit
most of those systems are plumbed with PVC, but some do use flex throughout the home...
If yours is PVC, visit your nutone dealer and get a new outlet/elbow.
Trim the old elbow off with a drywall saw or other small saw (if you have a sawsall, that is fine) and glue the new one in
if it is flex tubing, it's easier; the elbow threads on. just be sure to hold the tubing so it doesn't drop down,
Jan 02, 2009 | Broan-NuTone CV353 Central Vacuum
Problems with 353 nutone
if its an older unit or it got heavy use it could be the motor they tend to sputter as there going out, as it rotates the electricity hits a burnt spot inside the motor and shuts itself off can you turn it on manually? they usually put a swithc on the tank itself if the problem doesnt occur when you switch it then it could be the hose itself normally they control the off/on use a meter to check the continuity beteen the two copper plates that are on the end of the hose ( the wall end )
Sep 16, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone vx550c central vacuum
You ended chat so fast i guess that fixed ya ??
Aug 09, 2008 | Broan-NuTone VX475 Bagged Central System...
Broan-NuTone CV350 Performance Bagged Central System Vacuum Logo
143 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
