Question about Linksys Wireless-G WRT54G Router
How do you set it to mtu auto - Linksys Wireless-G WRT54G Router
    Scholar:
  • 39 Answers
1. access the router configuration page by typing http://192.168.1.1 in your browser. 2. This should pop up a log in window asking for user name & password 3. The default settings for a linksys router say to leave the username blank and type admin for the password. 4. This should bring you to the router configuration screen, and it should open to the Setup tab. if not just click on the word Setup then Basic Setup below. 5. MTU should be right below the Domain Name box the default setting is Auto. 6. If it was changed then click on the dropdown arrow next to the box and select Auto.
Good Luck
Posted on Oct 10, 2010
My xbox is telling me my network doesnt have a sufficient mtu setting and i needto go to my router configuration webpage and set the mtu to auto or 1364 or higher. i have no clue what im doing
Most routers reside at the following IP address: 192.168.1.1
Go to your computer (hooked up to your network) and type that address into your URL field in your browser. Default passwords for almost all routers is as follows:
USERNAME: admin
PASSWORD: admin
Once there browse through the options and settings tabs. Change NOTHING YET. You want to look for an option called MTU. You will probably find it in a 'Settings' Tab or 'WAN' tab. Most routers should have this set to AUTO as default. Once you find it, ensure this is set to auto. Save changes and turn your router off and back on.
Turn the xbox off and back on as well and see if this resolves your issue. If your router was already set to auto for the MTU setting and you are still having issues, go back into your router and access the section where you found the MTU settings. This time set to 1364 instead of AUTO and save changes.
Repeat the off/on process on the router and xbox and see if this fixes your issue.
Sep 13, 2011 | Blitzz Technology BWA711 Router...
When i hook my xbox up to my router it tells me that the mtu must be in auto or the setting must be 1364 or higher where do i do this
To check the MTU settings on the router , you will need to access the router set up page. Do you have any computer connected to the router and which is able to go online ?
If not then you will need to connect the computer to the router and check the IP address on the computer.
Open the set up page of the router and check the settings of the router.
Click Here for more information about the router and the network
Jan 22, 2010 | Computers & Internet
How to change mtu size
you will need to ope the router set up page.......
check the IP address of the computer. open the set up page of the router. on the set up page you will see the MTU. it might be on AUTO. change it to manual and change the size.
click save settings at the bottom. and power cycle the router.
Dec 26, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
It says my MTU setting isn't correct. I am connected directly to my modem which is the solution it gives when I test my connection, yet it still gives me the same message.
Have you changed the MTU setting? Generally, most things have this set to 1500. If you know where is it, set it to that (or choose AUTO if that is an option) and hopefully that will clear up your issue...
Dec 18, 2009 | Microsoft Xbox 360 Console
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Aaaaaaaahhhhh mtu xbox wont work getting fed up wot is problem
xbox live is down for maintainence it will be back up 2moro
Jun 16, 2009 | Microsoft Xbox 360 Console
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
Dynex mtu
Browse to the router's setup page and in Basic setup you will see MTU, change it from auto or default to 1500.
setup page address is 192.168.2.1,
Look under basic setup page.
Please remember to rate all Techs who assist you for free :) Good luck, Joe
Sep 30, 2008 | Dynex DX-E401 Router
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
