Question about Frigidaire Washing Machines
How do I run a diagnostic on a Frigidaire Model LTF7000es0
2 Suggested Answers
SOURCE: How do I run a diagnostic on a Fridgidaire
Diagnostic Test: The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360°, turn the Program Knob to start position, Drain/Spin. • Press Pause Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED’s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs. To clear latest stored error code: Place the control into Diagnostic test Mode. • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code. • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared. • Exit Diagnostic Mode to return th e w a s h e r t o n o r m a l o p e r a t i o n .
Posted on Dec 25, 2008
My Frigidaire washer, model FAFW3577KR is pausing through out the cycle. I can press play and it will continue and complete the cycle, but it's constant. What do I need to get to fix it?
sounds like the diagnostic board is having issues some model washers do offer a way to upgrade the diagnostic board's firmware check with the manufacturer to see if there's a way to update the washer's diagnostic board's firmware if not contact them to have the washer serviced
Feb 22, 2017 | Frigidaire Washing Machines
What is the ltf7000es0 error code E66
Hello friend, thank you for your post!
I understand that your Frigidaire washer is displaying an error code of "E66". An "E66" code stands for heating element relay failure. This could be a problem with your heating element or control panel. In order to properly locate the issue you would need to disassemble your washer and test each electrical component to assure it is providing an accurate reading. This is not a simple DIY job. I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
May 05, 2015 | Frigidaire Affinity ATF7000E Front Load...
My affinity front load washer will not complete any cycle and the display screen goes blank.. what could be the problem
Hey friend, I appreciate your post!
From my understanding your Frigidaire washer, LTF7000ES0, will not complete a cycle and the display will also go blank. It sounds like it could possibly be a problem with your control board, drawer, or lock switch. Since it could be any one of these issues I would recommend having a professional come out to your home and repair your washer. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Hello, I have a Frigidaire model LTF7000ES0 and it is frozen. I was washing a very small load and paused it to add more, when i closed the door and pressed the start button it gave me three quick beeps and...
Unplug it for 10 minutes. Plug it back in and see if it starts and runs normally. If it doesn't then I'd suspect the pressure switch first then the control board.
May 10, 2017 | Frigidaire Affinity ATF7000E Front Load...
sorry have no info on this model have you tried draining the mach manually then switch it back on i have seen this type of prob on other makes main control board is sometimes required
May 07, 2014 | Washing Machines
My frigidaire model is GLTF2940FE0 front loader will not start
I was wondering did u ever figure this out i have same code ...but mine will run a little water then drain and never spins but got the code E5E too
Dec 15, 2012 | Frigidaire Washing Machines
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a LTF7000ES0 frigidaire washer, getting error code E20. I have taken off the hoses from the water pump and cleaned them, there is a tube coming from the tub of the washer, in it is a device that...
E20 Water not pumping out fast enough. To get the front panel off,
as follows-----
Take out soap tray.
2 screws on back of top- and slide back.
5 screws & 3 clips on console, and fold out of way.
pull spring clip off boot and release boot.
8 screws ro loosen front panel
2 screws on door latch- and a clip to release wires.
---------- for detailed instruction click this link and check out other solution who solved this problem by themselves http://www.fixya.com/support/t178452-frigidaire_front_load_washer_ltf600es1 thanks.
Jul 11, 2009 | Frigidaire Washing Machines
Washing Machines Logo
81 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
