Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Timer light is blinking - Mitsubishi WD-52525 52" Rear Projection HDTV
    Sergeant:
  • 171 Answers
This sounds like you may have a bad lamp have you replaced it before if you have not I think the would be the place to start this lamps are made to last 2-3 years of use
keep this in mind as well Mitsubishi is know for there bad ballast board
here is the lamp your TV needs just in case
http://www.discount-merchant.com/SearchResults.asp?Search=915P020010
Posted on Oct 07, 2010
Our holiday decorations are blinking. I want constant light. How do I stop the blinking?
Photo eye is getting exposed to light, so the eye thinks it's day and turns off, but then it's dark so eye turns light back on: lights blink on-off
Read following troubleshoot resources:
http://waterheatertimer.org/pdf/Photo-eye-troubleshoot.pdf
http://waterheatertimer.org/How-to-troubleshoot-timers.html#photocell
Gene
Water Heater Timers Save Money
Dec 08, 2014 | Hardware & Accessories
Defiant digital timer has blinking light
Installed a Defiant light timer today. Light came on as scheduled, but is blinking. When I attempt to "toggle" OFF, it only dims, does not go OFF. When I move the switch from the ON to the OFF position, the unit turns the light off. Defective timer? HELP !!
Aug 14, 2013 | Defiant Timers: 5-Amp In-Wall Digital...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I baught a 3-outlet timer yardstake #15137. why does it blink on all settings except the on at all times?
Your yardstake timer has photo-eye that automatically turns lights on at dusk.
And then lights remain ON until set-time expires, or dawn arrives.
Timer automatically turns off at dawn, no matter which setting, unless timer dial set to ON
Photo-eye has to be turned away from outdoor lights or lights will blink.
That's because outdoor lights cause photo=eye to sense it's dawn, and timer turns OFF >>> a moment later photo-eye senses it's dark, and turns lights ON again.
Thus the timer turns ON-OFF.
Test this by putting black tape over photo-eye, or turning timer toward dark area. Timer should turn ON and follow set-time on dial.
Dec 11, 2010 | GE Hardware & Accessories
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
