Question about Delfield Freezer 6151XLSR Stainless steel
My freezer 6151 has build up ice on top of the unit. please help?
  • Delfield Master
  • 1,250 Answers
Start by verifying that the defrost time clock works. Located in the top of the unit. Let me know if we need to go any farther.
Posted on Oct 09, 2010
Our Whirlpool WV1600NFW freezer has frozen water forming on the front of all drawers from top to bottom. The manual's troubleshooting does not address this issue.
first thing you would do is turn off or unplug the unit for 12 hours then when you plug the unit in before hand you would remove the rear panel on the inside of the freezer. then pluging in the unit again you would have to distinguish if this is caused by your icemaker and the water not going into the ice tray or if you have a defrost issue with your unit where as one of the defrost pieces such as the defrost timer the defrost heater or the defrost thermostat is not activating properly when these pieces do not activate it forms a build up of ice around the evaporator which is found in the rear of that panel but I personally think the issue is coming from when the water comes into your icemaker and maybe the icemaker is not recognizing that it is full and continues to pump water into the unit or the tube that brings the icemaker water is not aligned properly. If you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to help others in similar situations and if you are unable to defrost by turning the unit off for 12 hours you can use a hair dryer to defrost the build up of ice Thanks Rick
Apr 21, 2011 | Whirlpool WV1800NFW Upright Freezer
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
My freezer started getting a lot of frost and ice around the top close to the henges. Now I am getting a lot of ice in the bottom of this freezer. I can break up the ice and remove it and it will be back...
there are only 2 reasons this happens but one cause (defrost element not working) 1st we check the defrost timer is working if not replace it if it is working go on to the last fault it can be - depending on the freezer it will have 1 or 2 defrost elements when one blows the ice will slowly build up if they both blow then the ice will build up within days unless you know your way around a multimeter it will be very hard to determin witch unit has blown in 70% of cases its the element but a service tech can tell you in a matter of minutes to save you time and money i would get a quote to get a tech in but now you know what to look for
best of luck to you
please remember to rate this repair .thank you
Aug 03, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Defrost hose plugs
Remove the back cover to access the top of that drain line. Take some table salt in a tablespoon and dump in the tube. Will drain so fast you won't believe it. Might have a big build up of ice blocking the top so get your hair dryer and defrost that big build up. Flush with small amount of water and monitor the drain pan located under neath the freezer. hope this was helpfull
Nov 26, 2008 | Arctic Air 22 cu. ft. Commercial Freezer...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
May 14, 2008 | Kenmore Freezers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Delfield Freezer 6151XLSR Stainless steel Logo
138 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
