Question about Whirlpool Refrigerators
We have a side by side whirlpool fridge. Model# ed5fhgxkq00. It pretty much died. The lights still work. We cleaned everything underneath,thinking it needed a good vaccuming, but no luck. My husband is pretty handy, so do you have any ideas what could be wrong? Thank you, Patricia Niles
    Genius:
  • 1,122 Answers
A DIRTY COIL WILL KILL THE COMPRESSOR LIFE,BUT MAYBE NOT,GO TO YOUR LOCAL APPLIANCE PARTS STORE AND ASK FOR A 3 IN 1 START KIT,PULL REFRIG. OUT FROM WALL,REMOVE LOWER BACK PANEL,REMOVE CAP ON COMPRESSOR NOW LOOK ON THE STARTER YOU JUST GOT AND IT SHOW YOU HOW TO HOOKUP,IT EASY,IT'S LIKE JUMP STARTING A CAR ACCEPT YOUR JUMP STARTING YOUR FRIG.,MAKE SURE YOU UNPLUG FRIG. BEFORE YOU START,THANKS-MIKE
Posted on May 29, 2008
Removing the water pan underneath the fridge.
You would hope it was accessible from the front, but no. You probably have to roll the fridge out, not breaking the water line, and get to the pan. You may have to remove the paperboard rear cover, usually takes a 1/4": nut driver. Vacuum out all the dust while you're back there.
Nov 26, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
I have a side by side Whirlpool fridge and the ice maker is not working. If I have it turned on (lever down) and door is closed and water leaks out the front of the ice dispenser and it doesn't seem to...
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
Jun 10, 2010 | Refrigerators
Whirlpool ED5SHAXMB00 freezer stopped working, then fridge. cleaned underneath completely. fan working. hearing click coming from relay switch on outside of condenser. now what?
This clicking noise is the relay on the side of the compressor. It has been damaged and not working properly. Simply replacing this should be able to start your compressor! I would be VERY surprised if this was not the problem based on your description. I looked up your model number and this is the part number you need - 8201786. This is a kit and the only way to get this part. The instructions should tell you everything you need to know. If I can be of further assistance let me know! good luck!
May 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Odor
Could you possibly have a dead rat under there? I know this sounds gross, but they love to hide in the electronics. (Sorry). Anyway, your drip pan may sit on a small bracket type piece that isn't heavy at all. It can sometimes get misplaced, causing the fridge to leak because it's out of place. If you can get a flash light, you should be able to see where it's placed and you should be able to remove and clean it out. I put Mr. Clean in mine when it gets an odor and when water hits it, the solution cleans the odor, but you can clean it and replace it. I hope this helps!
Aug 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Cannot remove plastic skids from under my new whirlpool fridge
The skids are bolted to the refrigerator from underneath. I think they are 13mm or so, you need a friend to help you tilt the fridge and then unbolt them from the bottom.
Aug 17, 2008 | Whirlpool GS6NBEXR Side by Side...
Fridge side by side and freezer not cooling
The fridge is working again and I don't understand why. Thanks anyway all is good.
Jul 22, 2008 | Whirlpool GS6NBEXR Side by Side...
I have a ed5fhgxkq00 side by side Whirlpool refridgerator that stopped cooling. It worked fine up until last night when we noticed that the ice was melting. Now it gets a little cool but not cool enough....
If the compressor has a fan next to it, be sure it is running. if the relay is clicking every few minutes it may need to be replced. contact local parts distributor.
Nov 04, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
141 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
