Question about Radio Shack 15-2200 Remote Control
For some reason, the remote just stopped working. I would press the buttons to try and get a certain channel or increase the volume and the light would blink but there was no response. My first thought was to change the batteries but that didn't work. I then proceeded to try reprogramming the remote for the TV but it had no effect. I was wondering if this could be a remote issue or if it is a problem with the TV which seems to be working fine.
    Problem Solver:
  • 18 Answers
SOUNDS LIKE A REMOTE ISSUE,IF ITS NEW I'D TAKE IT BACK,IF NOT I'D BUY A NEW ONE LIKE RCA OR ONE FOR ALL,THEY ARE BOTH RELIABLE REMOTES,STAY AWAY FROM RADIOSHACK AND SONY REMOTES"JUNK".
Posted on Oct 07, 2010
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
Volume increases to 100 or drops all the way to 0 when pressing the volume button on either the remote or back of the tv. I can't control the volume I want.
Keyboard issues and answers:
A problem that is more common than most people think is anissue with buttons on the controlkeyboards of modern TV sets.
Recently for whatever reason I have seen more questionsabout this so I have composed this answer and solution for these kinds ofproblems.It can be any button on the set-channel up/down or volume updown-you name it.
The symptoms are the same: channel will scan up or down andwill not stop-remote control has no effect on this---It can be channel, volume,or even input or menu if the set has those up front or on the side of the set.
All these push controls have something in common-beneatheach is a tiny momentary push switch-when pushed with the plastic button itperforms a specific task (vol up or down etc.).
What happens is the afflicted switch beneath the plasticbutton is bad-when released it is supposed to stop its function but does not.
Keyboard or button controlled features have PRIORITY over the remote control, hence the remote will not stop this fromhappening.
Both the remote and thekeyboard go to the microprocessor in the set but keyboard is first in line.
How to resolve this issue?
Someone needs to get at the tiny pc board with the buttonsand locate the one associated with the issue (ie sound or channel etc) andunsolder that switch from the board-usually just two pins (may be more formounting only purposes) and then see if set does not have the issue with switchout of the circuit.
For the TECH minded with the board out test here theswitches with a ohm meter set to high resistance-any reading with button notpressed means a bad switch-seen ones that read 5,000 plus ohms-it may benecessary to unsolder more than one switch to locate the offender here but an open reading with switch not pressed is therule.
I have taken the time to compose this answer as some do notunderstand what is happening in these types of situations---No magic wand orsmoke and mirrors here-have to disable the offending switch to know.
The beauty (in my view) of this kind of problem is if found, you really do not have to replace anypart-just operate the set with the remote with one button that no longerfunctions on the set itself-who could ask for more?
SD TECH
May 30, 2012 | LG Televison & Video
My remote won't let me channel down past a certain channel, I can type the numbers in and it will go but if I try to arrow down channels it goes about 5 channels and then starts back over where it started,...
mp_383
What channels are you able to receive? When you press the Select button on DISH remote, which light on the top of the remote lights up? The Sat button should light up when you are in satellite mode. If any other button lights up, press and release the Sat button and then try changing channels. If this doesn't work, we may need to troubleshoot with you. Please call us on 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Mar 08, 2011 | DISH Network 135899 Remote Control
I m trying to program my RC64 remote for Direct TV and as soon as I press the mute/select buttons in order to put in the codes it says that my remote isn't programed for the TV yet so I cannot press that...
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Jan 09, 2010 | RCA DIRECTV Satellite Remote Control
The samsung lcd tv remote control has stopped
Hello Jacqui,
When you press the number button or other buttons on the remote do they Feel Stuck? The reason I ask this is every remote I have ever Had always ends up getting something spilt on it.
If It feels like the button are sticking then you could always try cleaning it with a baby wipe or something similar Not a sopping wet cloth.
If the remote seems to be ok you can always check your remote is working. Firstly you will need a mobile phone that has a Camera on it.
With you mobile set it up so that your camera is on. Now what I would like you to do is Point your Samsung TV remote at it and press the buttons. Whilest you are looking at your remote through you phone you will notice that a light appears. This is due to the camera Phone not liking infra-red, ( you can not see this with the naked eye.) So try your power button and you will see what I mean. Now try the other buttons and you will see which buttons are not working and those that are.
If after doing this that certain buttons on the remote are not working full stop what I would suggest you do. Rather then buying another Samsung remote as they can be really expensive.
There is another way. A lot of your friends / family or maybe even yourself may have a Sky Remote lying about not doing anything.or you can buy them from Argos cheap enough.
Please follow the steps below and you will be able to tune your Sky remote To operate you TV
with the sky remote then.
Press TV
RED + SELECT ( hold this down until it flashes twice)
TV
0060
Try the volume if this works then press SELECT to save this to the remote. If not then press TV again then check the volume repeart this step until the volume works then Press SELECT to save the code to your remote.
Hope this helps you out and saves you some money buying an expensive replacement.
Thanks
Little Dish Fitter.
Nov 01, 2009 | Protron PLTV-32 Television
Tv channel is automatically changing
sounds like it need some cleaning , or main board might be disaligned , open it and take a look at the plastic buttons that touches the main board switches , good luck , AJ
Oct 24, 2009 | Televison & Video
Volume on sky+ remote
my sky + remote has stopped working the red light comes on when i press buttons but nothing happens
Apr 06, 2009 | Televison & Video
Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Mar 22, 2008 | Philips 32PF5320A 32 in. LCD Television
Channel memory reset
Bryan,
Usually the menu can be accessed from the buttons on the console, sometimes by pressing a "menu" button but other times by pressing both Volume or Channel (+ AND -, UP AND DOWN) buttons simultaneously. Menu levels are usually selected with one or the other of Volume or Channel, and toggles/selections with whichever doesn't do the levels.
Nov 05, 2007 | Sharp 27K-S300 27" TV
Radio Shack 15-2200 Remote Control Logo
81 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
