Question about Ricoh Aficio 450 Copier
Using 450 as a printer
How do you connect the 450 to a Mac or Windows computer....i can't find the terminal...what kind of cable is it? thanks for any help! steve in baltimore
  • steve21230 May 29, 2008
    sorry i meant the ricoh aficio 450
  • 30 Answers
Not all aficio 450 have a printer controler on them but if it does there will be a port either parralel or cat 5 network on the left and side rear behind the collator if it as one
Posted on May 30, 2008
I have a citizen 3550 printer how can i hook it up to my computer to print out misc. things instead of using you conventional printer?
Thank you for posting to Fixya.com and it is my pleasure to guide you.
To help you in the furture I have found the manual for reference. Click the link or copy paste it to download it. http://www.posguys.com/download/iDP3550UME_09E.pdf
From the manual for the Interface Cables, the manual has pictures.
4.2 Connecting the Interface Cable
1. Turn off the power. (Mating side included)
2. Check the top and bottom of the cable terminals, and connect to the interface connector.
3. Secure the cable terminals.
Serial interface: Tighten screws to secure.
Parallel interface : Turn clamps to secure.
4. Connect the interface cable to the computer.
4.3 Connecting the Drawer Kick-Out Connector
2. Check the top and bottom of the drawer kick-out cable connector and connect it to the drawer kick-out connector located at the lower section of the printer.
3. Screw the grounding cable of the drawer to the grounding terminal located at the lower section of the printer.
CAUTION: • Connect only the prescribed drawer (Solenoid) to the drawer kick -out connector.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 21, 2011 | Citizen iDP-3550 Matrix Printer
Driver for lexmark x1270 for mac
Your Lexmark X1270 printer was designed for rosoft Windows 2000; Microsoft Windows XP; Microsoft Windows XP Professional x64; Microsoft Windows Vista; Microsoft Windows Vista x64; and Microsoft Windows 7 as it is indicated in its webpage. Remember, drivers and softwares are always limited from the manufacturer's releases. I recommend that you upgrade your printer to a Mac compatible printer. You may choose from this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
May 12, 2011 | Office Equipment & Supplies
I have my problem about my printer I cant install the driver please help me
It would help to know what platform you're using (Windows or Mac) and what operating system you're using. Drivers differ from one to another, and sometimes there will be different versions of the same driver for the same operating system (OS).
Mar 02, 2011 | HP Office Equipment & Supplies
What kind of cable connects the scanner to a pc
Take a look at this picture:
The while cable with two flat ends is the cable that connects the scanner to the computer. It's called "Parallel Cable". Here's the picture:
You can buy it from here (Click Here)
If I am right, this scanner has also a usb port, if so, you can use this type of cable, Hp USB Printer/Scanner cable:
Terminals/Ends:
If you have problem, let me know.
Good Luck.
Thanks for using FixYa.
Jan 09, 2011 | HP ScanJet 5370C Flatbed Scanner
Hi i have a lexmark printer that i use to have connected to an old computer but now need to connect it to my netbook. The paperwork for the printer has x1100 but the printer has x1180 on it. My problem is...
Before you connect the printer via the USB cable to your netbook, check the version of the operating system(e.g. Mac or Windows - XP, Vista or Windows 7). If you are using Vista or Windows 7, check if it's running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. NOTE: USE VISTA DRIVER IN WINDOWS 7. FOR MAC, ONLY WORKS UP TO 10.3 version.
You can download the Lexmark X1180 driver by visiting the Lexmark website at http://bit.ly/9W56vE. Click on "change OS" to select your operating system (see image):
Then click on "FILTER" (see image):
Click on the driver under "Recommended Downloads". Download, execute the file and follow the instructions in the software.
Hope this helps. Let me know if you need further assistance or you can also contact Lexmark technical support. Thanks.
Nov 01, 2010 | Lexmark C533DN InkJet Printer
SHOW ME THE CORD FOR HOOK UP TO THE COMPUTER AND WHERE DO YOU INSERT?
Son of a ... They don't give you a USB cable in the box.
General Specifications OS Compatibility
Windows Vista™, Windows XP/2000 and Mac OS® X v.10.2.8 to 10.5.x9,11
Standard Interface
USB 2.0 Hi-Speed, PictBridge (Cable not included)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=15603#ModelDetailAct
* It should be a standard USB 2.0 cable.
Well you need the kind that connects a printer. Type A connector on one end and type B connector on the other end. See this page.
http://en.wikipedia.org/wiki/Universal_Serial_Bus
and see this page for a better picture of the cable...
http://www.amazon.com/Belkin-F3U133-10-Hi-Speed-Cable-Feet/dp/B00004Z5M1
one end is kind of square with rounded upper corners kind of like a house, the other end is the standard flat rectangle usb connector that everyone knows from plugging in those USB memory things.
Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
I am getting the print cartridge allignment sheet repeatedly.
Please visit www.hp.com then search or click the printer tab to the product side and search the HP Director and download it.
thanks
Aug 13, 2009 | HP PSC 2410 All-In-One InkJet Printer
I have a hp 450 printer and a new mac book. Is there any way to get a converter cable to work these 2 together?
Yes...............
Your HP 450 should of came with a high-speed, bi-directional connection cable that goes between your USB port printer and PC or Mac.
Hewlett Packard recommends the HP USB 2.0 Printer Cable for your printer to Mac.
If you shop the web, or your town, you will be able to purchase the cable. One important thing to do is install the "MAC" HP 450 Printer Drivers on your new MAC first before plugging in the Printer. If you lost your install CD, you can download them free at www.hp.com - drivers and support.
As you know "B" goes to the printer and "A" goes to the Mac.
Plugs Receptacles Series A usb-a-plug.gif usb-a-receptacle.gif Series B usb-b-plug.gif usb-b-receptacle.gif
Jun 17, 2009 | HP DesignJet 450c InkJet Printer
ZR85
Hi! If you go to the Canon, they have a trouble shooting section. I copied and pasted some information below. Good luck!
Details Print Friendly Version Issue: How do I transfer video tape recordings to a computer via Firewire?
Solution: Transferring video recordings to a computer ZR80, ZR85, and ZR90
Transferring Video Recordings to a Computer You can transfer recordings to a computer using the IEEE1394 (DV) terminal. With the ZR85 and ZR90 transferring video recordings via USB is not possible.
Before starting the video transferring, make sure to prepare the following:
  • A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing board (the IEEE1394 protocol is frequently also called "Firewire" or "iLink").
  • A DV cable (sold separately)
  • Video Editing Software
You can use (1) the video editing software that came bundled with your computer or video capturing board, (2) the video editing software included with your operating system ("Windows Movie Maker" with Windows Vista Home Premium, Windows Vista Ultimate, Windows XP and Windows ME, "iMovie" with Mac OS 9 and later), or (3) video editing software purchased separately, with features ranging from very basic to very sophisticated.
  • The appropriate driver
A driver is included with Windows operating systems later than Windows 98 Second Edition and Mac operating systems later than Mac OS 9. The driver is installed automatically when you connect the camcorder to the computer. No additional driver is necessary or available.
  1. Start your computer.
    (If this is the first time you are connecting the camcorder to your Windows based computer your computer will display the "New Hardware Found" message while the driver is installed automatically.)
  2. Set the camcorder to playbackicon.gif mode.
  3. Connect the camcorder to the computer with the DV cable as shown below. Once the camcorder and computer are connected together the camcorder will display "DV IN" on the LCD/viewfinder. This message confirms that the camcorder is ready to receive or transfer video.
  4. Refer to the instructions for your video editing software to download your video from the camcorder.
    Note: Because procedures for digital editing software applications vary greatly, Canon cannot offer any additional support or suggestions regarding downloading and editing your video. Please refer to the software publisher or your computer manufacturer (if the software came with your computer) for assistance in using the software.
  • Operation may not work correctly depending on the software and the specifications/settings of your computer.
  • If the computer freezes while you have connected the camcorder, disconnect and reconnect the DV cable. If the problem persists, disconnect the interface cable, turn off camcorder and computer, turn camcorder and computer back on and reconnect them.
  • Before connecting the camcorder to the computer using a DV cable, make sure that camcorder and computer are not connected with a USB cable, and that no other 1394 device is connected to the computer.
  • We recommend powering the camcorder from a household power source while it is connected to the computer.
  • Refer also to the instruction manual of the computer.
  • The programs ZoomBrowser EX and Image Browser included with the supplied CD-ROM are intended for use only with images recorded on the memory card.
  • Video recordings on the tape cannot be transferred to the computer using the software included with the supplied CD-ROM.
Nov 07, 2008 | Video Cameras
Ricoh Aficio 450 Copier Logo
99 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
