Question about Equity Time USA Audio Players & Recorders
MODEL 30227/30228 CAN THIS WORK ON A9VOLT BATTERY ONLY.
Valet remote car starter
no year car?
no model or sub model?
is this a factory installed options? y/n
sure , stronger battery can give you more RF signals (it's a radio transmitter, and as such will be weak if battery is low.)
Jan 22, 2014 | Honda Cars & Trucks
I have a Kodak EasyShare M341 - when I push the on/off button the lenses extends then retracts. It just will not turn on. I have charged the battery and even bought a new battery but the same thing...
Same issue with an older easy share model what i did was leave the batteries out for a few hours then tried new batteries. that worked for a short time. then i realized the model actually shorted out. i hope thats not the case. that model should work as a webcam if it does plug it in via usb with the batteries and if it still does that then your model is fried. also if you cant transfer files from your camera to the comp its fried. please let me know if this helped.
Mar 14, 2011 | Computers & Internet
My lap top HP compacq nx6310 model working satisfacorly with AC power adaptor connected and showing battery charging led orange continuesly. when power intrupts or on battery the laptop wont switch on....
First try removing and installing the battery once. May be loose connection.
Second, may be battery problem, to confirm try battery health checker from HP http://h20239.www2.hp.com/techcenter/battery/battery_ts.htm
ftp://ftp.hp.com/pub/softpaq/sp41501-42000/sp41862.exe
If laptop is within warranty, call the support to fix it up for you.
May 18, 2010 | HP Compaq nx6310 Notebook
Missing a battery for a Sportline Model 342 Pedometer.
Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
Oct 23, 2009 | Sportline Exercise & Fitness
Model 27958GE 1-A Handset stopped working. Base
SOMETIMES IT MAY REGISTER AS THE BATTERY WORKS BUT IT IS DRAINED OUT TRY TO CHANGE THE BATTERY AND ONLY CHARGE IT WEN THE BATTERY IS AT THE POINT OF EMPTY OVER CHARGING WILL DRAIN THE BATTERY HOPE THIS WORKS FOR U
Jul 14, 2009 | Uniden Cordless Phone
Battery needs to be replaced in eletrolux pronto 2 in 1 stick vacum,can i order one
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther model with the same specs and my PRONTO is working fine now. The battery model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
Sep 02, 2008 | Electrolux Vacuums
67 people viewed this question
Top Equity Time USA Audio Players & Recorders Experts
handy2011
Level 1 Expert
Tom Chichester
Are you an Equity Time USA Audio Player and Recorder Expert? Answer questions, earn points and help others
