Question about Miele Washing Machines
I have a Miele Paragon Plus (1/1/2007). Noticed that half way through a wash the program appeared to have finished and the light was flashing for the program to start again. Inside the laundry was wet and heavy. Put it on a spin program, same thing happened a minute into the spin. Tried a final time and the time counter started to flicker and fade. Then the machine stopped completely. Now cannot get it to turn on at all. Have checked fuse, circuits, plug socket and all ok with other appliances. Could it be an electrical fault inside the machine
SOURCE: samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Posted on Jun 27, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
SOURCE: Not finishing the wash cycle
I have now solved the problem with our WFxxx washing machine. I was moments away from doing the same (dumping it and buying a new machine), but thought I would take the back off and look to see if I could find anything obvious first.
I am not very technically minded so I was well pleased with myself when I fixed the problem and saved myself a small fortune on a new washer. I was also amazed that it was something really simple that nearly cost me loads of money. The problem cost me nothing to repair but I got a bit wet (a small price to pay).
The problem was caused by a blockage in the sump Assembly.
I removed the small cover plate at the bottom of the back cover (held on by just 2 screws). This gives access to the drain pump and sump assembly. Using a flat bladed screw driver I removed the hose clip securing the sump assembly to the main drum outlet. I also removed the clips securing the sump assembly to the drain pump and the clip securing the pressure sensor sender tube to the sump assembly.
All clips removed I then removed the sump assembly from the main drum. At this point a got a good soaking as trapped water gushed from the main drum outlet!!
Inside the sump I found about £2 in loose change and several paper tissues. (Someone's not emptying their packets before doing the laundry!!!). This blockage was preventing the water from draining away from the drum effectively.
After removing the coins and the rest of the gunge that was causing the blockage (not a very pleasant job and a bit smelly!!), I washed out the sump Assembly in hot soapy water and re-assembled the whole thing. The machine has worked perfectly ever since. The whole repair process took me about 40 minutes and saved me a fortune!
Sump Assembly complete with small-bore pressure switch tube. (Below)
f16e905.jpg Pressure Switch (Below)
Why did the blocked sump assembly effect the wash cycle?
As I said earlier, I am not technically minded so this is simply my theory of what went wrong.
When the washing machine is draining, water entering the sump is forced up the small bore tube to a Pressure Switch. While there is water pressure pressing against this Pressure Switch, the machine knows that there is still water in the main drum and will not move on to its next part of the wash cycle until the water pressure on this switch is released. Because of the blockage in the sump, the pressure was not released from the pressure switch causing the wash cycle to come to a stand still.
I hope this helps other people experiencing a similar problem with the WFxxx models. A very easy fault to fix (once I discovered what was causing it) and It's certainly cheaper than buying a new machine!
Posted on Sep 19, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
MakeupWizard
  • 39 Answers
SOURCE: washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Posted on Apr 22, 2010
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
MIELE G646 Wonderful machine, but now 10 years old ! I noticed a small leak on the floor which appeared to be coming from the bottom of the door, on both sides. This was noticed after a programmed wash...
Clean gasket with clorox to remove any funk, and apply vasoline to gasket to improve seal. If you still have water leaking, you will need to replace the seal on the dishwasher. Should be able to order from an appliance parts dealer, or they may provide a univeral gasket that would fit your machine.
Jan 07, 2012 | Dishwashers
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I'm looking for a service manual for Miele WS 5425 washing machine, any ideas where i can obtain one?
i have a Miele ws 5425. it wil not open even though though the cycle has finished. It still full of water. The red fault light flashes on the drain symbol.
Jun 17, 2010 | Miele Washing Machines
The water plus light is on what does this mean
To switch off the fault indicator: switch the washing machine off with the
I-On/0-Off button and turn the programme selector to Finish.
You gave no model number but here is the site for instructuons.
http://www.miele.co.uk/customer/
Try the reset first.
Aug 19, 2009 | Miele Washing Machines
The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Half way through a program then stops, leaving water in the bottom of the machine
Check the flood switch first. It will stop the dishwasher but you may hear a moter running.
Jul 21, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Washing Machines Logo
221 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
