Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
How do I use the sanitize drum cycle on my BOSCH front loading washer?
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
  • 8 Answers
SOURCE: Washer doesn't complete cycles
Sounds like an electronics problem. Get a Bosch repair person to look at it. Hopefully, they can reset the computer inside. Otherwise, it's a part that costs more than $200, as I recall, plus too much to do the work. Bosch's 1-800 person once advised me to unplug my washer - a model 2401 - for a half-hour as a way to reset the electronics. You might try that. Pray to the appliance gods. Maybe your machine is still under warranty. Trouble is, you'll probably have to wait for days until an authorized, over-priced repair person comes to visit. Bosch is way behind in service levels here in the U.S. They know it, but it's not worth their time or money to fix, it seems. A long story ....
Posted on Sep 20, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
  • 23 Answers
SOURCE: putting on spring loaded wire seal ring on a bosch washer
You have to make sure that the spring part is towards the bottom of the front. If you look closely at the washer at the bottom you will see a groove. That groove is where that spring will need to end up otherwise the whole thing will keep poping off.
how I install is I use a 90 degree pick tool. I work the edge of the seal with the metal ring and making sure it lines up with the groove. once there is tension on the spring I streatch it with the 90 degree pick tool and continue to work the rest of the gasket around. Once you get that completed I push down on the spring to make sure that it is in there. If it is not it takes one door opening to make it fall all apart and you have to start over.
Posted on Aug 13, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
How do I use the bosch washer drum sanitizer cycle?
I don't have my Bosch washer any longer, but if I recall correctly there is a specific "cycle" for the sanitizer cycle, just drop in the tablet ( a specific product for high efficiency washers) and run the cycle.
Jun 07, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
LG front load washer leaves clothes soapy. Yes cleaned trap and drum and use correct HE detergent. What else can it be?
front load machines can be soo frustrating-try using less detergent-you might try running a sanitizing cycle with a quarter cup of dry dish washer soap-sounds like your rinse cycle isn't working do you have an option for a 2nd rinse cycle-cheers Denny
Oct 26, 2013 | Washing Machines
Hello there, We have mold which is hard to remove in the liner of our loader and it also drips down the front of the washer when we have ran it. Do you any advice for removal of mold and to stop the...
Hi Clare. Yours is a common complaint, but easily remedied. In your owners manual, you will find that it is recommended to run the "sanitize" cycle every 30 days. This will kill any mold or mildew inside the machine, and keep it from smelling inside. If you havent been doing this, it will be a little harder to get it clean. The sanitize cycle heats the water to 185 degrees ( approx.) My advice would be to run a sanitize cycle once a week for the next month. Put a cup of bleach in the detergent dispenser each time you run the sanitize cycle for the next 4 times ( without clothing inside). Also, leave the door open overnight after completing your wash. This will allow the internal wash drum to dry out and eliminate any chance of mold or mildew inside. When you see a drip down the front of the machine, it is usually lint or hair stuck to the bottom of the glass door where the seal contacts the bottom of the door. Keep this area clean and lint free and your leaking should stop.
Feb 21, 2011 | Miele W 4800 Front Load Washer
Cycles but the drum desn't spin
check the drain pump and make sure it is not plugged if there is anything stopping the pump the washer will not function.
you may also need to check the door lock
Mar 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Smell of mildew on our towel and sheets
This is probably happening because the clothing is being left damp in the washer. When it is warm during the summertime mildew will grow very quickly in the towels. On front load washers you need to leave the door open when not in use to keep mildew from growing. You should wipe out behind the inner seal any moisture when you are done doing laundry. This is an issue for most front loaders. Some front loaders have a clean washer cycle that uses bleach to sanitize the drum. Other washers like the Samsung have a block of silver and release silver ions in the wash to sanitze the clothes.
Sep 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
940 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
