Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Unit runs for one and a half hours then shuts down
    Scholar:
  • 146 Answers
Check the fuel filter on the units as well as the inlet and outlet filters on the back of the motor.
Watch the nose cone and see if the end starts to loose the glowing orange color before it quits.
If the unit slowly looses the color then you have a fuel problem but if the unit just quits at full heat then you could have a electrical problem.
Posted on Oct 07, 2010
Dryer runs for 30 mins then all lights flash and machine wont start
oh oh bad windings on motor usually runs for about 20-30 minutes hen shuts off cant start agin after a half hour?
Feb 05, 2015 | Washing Machines
UNIT SHUTS DOWN FREQUENTLY
How soon after starting does it shut down?
The hour meter is fed directly from the AC output off the generator stator, if there is no AC output the meter will not run. Assuming it shutdowns quickly, check 1st the oil level and make sure the low oil sender unit is ok, wire #24 to ground. If that is bad it will shut down. Check to see if you have 240V on L1 and L2 on the breaker for the brief time it does start, that will confirm stator/rotor has an output, then your problem moves from the generator portion to either the oil sender, or control board.
Feb 24, 2013 | Powermate Coleman Standby Generator...
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
My Cub Cadet 2130 has a Kohler Command 12.5 Hp engine. I have had a recent problem where if I shut the engine off after running for a half hour or so it won't restart. Today it died on it's own...
You most likely need to replace the ignition module. You should find it under the shoud next to the flywheel, just follow the spark plug wire.
Sep 18, 2011 | Garden
I have a carrier outside unit 38YKB036310 unit It comes on & cools but after around a half hour it shuts down. The fan motor feels hot I replaced it (the fan motor) & still have the same problem.
does just the fan motor shut down and you can hear the compressor still running when this happens?
did you replace the running capacitor for the new motor? is the motor a compatable replacement? how many amps is the motor drawing?amps should be close or under nameplate rating? is the outdoor coil clean?did you reinstall the fan blade the same depth as the old one?do you have the proper voltage to the motor?
Jun 21, 2010 | Heating & Cooling
Engine shut down after 15miles then won't start for half hour
just went thru the same think wit a s 430 it was the crank position sensor . 60 bucks at auto zone and it took me 5min. 2 install if u need help feel free to call me 918 808 9706 chris
Feb 20, 2009 | 2000 Mercedes-Benz S-Class
Sanyo plv z4 shuts down
call sanyo tech department and they will help you increase the fan speed to cool the unit. This is done with the remote so it was pretty easy. Make sure your filters are very clean first (use compressed air or a co2 canister. Have not had a problem since, my units run on average 8 hours a night and have not shut down.
Nov 09, 2007 | Sanyo PLV-Z4 Multimedia Projectors
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
29 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
