Question about Sony Playstation 3 (PS3) Console
Brand new ps3 right out the box won't accept a disc. pressed eject there is nothing in there. should i take it back or is there a quick fix?
The problem is the lazer is broken or out off allignment can be solved witha replcement lazer len unit it a common fault
Posted on Oct 07, 2010
Disc stuck in console how to get it out?
I had this problem recently. I got mine out using a thin butter knife. The disc had some sticker residue on it that bonded to the drive when it got hot.
> Carefully ease a long knife (or something very thin) through the felt opening. Stay above the top of the disc (printed side). Then gently hold down on the disc while pressing the eject button.
I wouldn't recommended taking the PS3 apart. Not only will it void the warranty, but it is kinda tricky getting it back together. Besides, this won't really give you better access to the disc because the disc drive is an enclosed metal box.
If there is no (belt rubbing) sound when you press eject, the disc drive probably needs repair/replacement.
May 26, 2012 | Sony Playstation 3 (PS3) Console
When i turn my PS3 on the light goes from red to green but nothing else happens, the discs load and eject thats it. You cannot turn the system off without turning the power off at the wall.
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
My PS3 won't accept any disc. It's blocked at the opening.
hello take the power lead out of the back now replug it back in while doing this press and hold the eject button you hear the fans boot up. if there's a disc in there it will come out good luck
regards
shaun
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Blinking red light, will not operate, will not eject disc
its called the red light of death in order to eject the disk you have to 1.power off the console
2.Press the eject button and the power button while turning the switich back on on the back of the ps3
3.wait a few seconds and the disk should come right out
hope that this is useful!
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
The drive will not eject games, and will not read games once removed. The drive just makes a whirling sound and I have to hold the ps3 @ an angle just to eject games. And now the drive won't accept...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the PlayStation not ejecting discs is a bad drive.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This drive should fix any issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PlayStation including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PlayStation going again!
May 27, 2010 | Sony Playstation 3 (PS3) Console
A game is stuck inside my almost new PS3 and it won't load. Is this a common problem? Is there a quick fix?
the motor that pushes the games/movies out could be broken. a quick fix is gently tapping the console and the disc should eject. since you state that it is almost new send it back to sony they will fix the motor for you under the warranty
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
My disk is not ejecting from my ps3. my pro evo 2009 has been stuck in for a while now. when te eject button is pressed it attempts to do so but then nothing comes out and it goes back to normal (as if...
is there a tiny whole in your ps3? in which you could insert a small pin? if not. then the disc tray may be stuck. you could try lifting the disc tray with a pliers or something that can hold the tray and slowly pull the disc tray as you press the eject tray. Pm me for any clarifications.
Aug 07, 2009 | Sony Playstation 3 (PS3) Console
Wont accept disc
Try this....after a lot of frustration and research, what i found on the internet for this problem was usless. I tried holding down the eject button for 15 seconds to reset the disc drive, still it would'nt accept the disc. As i literally picked up the phone to ring sony, as the ps3 was on standby i pressed the eject button multiple times and heard 2 beeps each time, still the system stayed on standby. After that i then tried just putting the disc in as normal as its on standby and the system booted automatically and accepted my disc. I hope this helps others, as mine now works perfectly.
(PSN ID is Burnsy333)
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 WONT ACCEPT DISK
I bought a PS3 yesterday and had to take it back - when entering a disk it would get pulled in and start to spin but would only go in still leaving about a half inch sticking out - it would spin for about 15 seconds and then stop. I had to take it back and get a replacement which worked fine.
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't take disk
i kept my finger on the eject button whilst having disc half way in and then i turned ps3 off and on by pressing standby button. it magically accepted the disc eventually and all was good - had to give it a few go's though
Dec 23, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
