Question about Dryers
Gas Dryer Sometimes Buzzes when burner comes on
Illeagle,
Thanks for replying. I somehow got the wrong dryer model number in the original message - I have the MDG5806AWW dryer. I assume though that the model number doesn't change what you think is wrong with my dryer. It is out of warranty (two years old in August) so I would like to pursue fixing it. I replaced parts in a Kenmore dryer I hade a few years ago so I don't mind going after this one. I assume I need to find out the part number that nees to be replace and then try to order it. How do I find out the specifics of getting the part?
Also, I had a question about the different sensors that are hooked to my dryer. I attached a picture below of the burner area. It shows 3 different sensors - one at 9 oclock, one at 12 oclock and one at 1 oclock or so. I was wondering what each one does.
Thanks again,
George
  • Shuttleguy Jun 09, 2008
    illeagle,
    I am back in town and need to get back to my dryer. In your reply above, you mention that I need to replace the two black coils which should stop my "humming" sound. I just want to be clear about this noise in case it ends up being a different problem than you originally thought. The noise I have tried to describe is a very loud buzzing noise - nothing close to a hum. Does this change anything?
    I was looking on repairclinic.com and found a listing for a "gas valve componenet" for my dryer, but it is the gas tube, the coils and valves all in one large assembly (Item # 1068141). Is there a way to just replace the coils? If so, would you know where I could find the parts?
    Thanks again for the help.
    George
  • Frank Oct 13, 2012
    I replaced these coils in my Maytag Dryer with new ones however I am still having the same issue even with the new ones. Is it possible that there is something wrong with the Valve unit itself?
  • 525 Answers
Ok George! Nice work.
The 2 black coils with insulated terminal connections are the ones you need to replace and that should stop your humming noise. The unit on the left side of flame shroud is the flame sensor.This controls the glow bar function. The item at position
1 o'clock on the flame shroud is your Hi-Limit thermostat. This protects the dryer from an overheating/fire scenario. I can't tell from the picture but there should also be a thermal fuse by the Hi-Limit t'stat. This is in place just in case the Hi-Limit fails to open in an overhat scenario. The Glow Bar is mounted up at the end of the the and to the left of the venturi, (flame tube).
Hope this helps you find your way around your dryer a little easier.
Dave E
Posted on May 29, 2008
  • David Emmel
    David Emmel May 29, 2008
    I need to clarify something to clear up any misunderstanding.
    The unit at 9 o'clock is still the flame sensor.
    The unit at 12 o'clock is the Hi-Limit t'stat
    The unit at 1 o'oclock is the thermal fuse
    Sorry for the confusion, I misread your comment,(My Bad)
    Also, could I impose on you give me a rating so I can keep track of my errors? LOL
    Thanks again,
    Dave E (Illeagle)
Have a Samsung gas dryer, power comes on and panel lights up. push start button and lights come on but nothing happens, dryer won't start???
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Jul 04, 2011 | Samsung Dryers
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
I have a Whirlpool Gas dryer LGR5620KQ1. The dryer spins but when I start it, it buzzes then clicks but no heat comes out. It only makes teh noice when I select the "heat" portion of the cycle. I...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Whirlpool Dryers
Kenmore gas dryer does not get hot enough. Gas burner does not seem to stay on long enough. Model 110.72912100
heatman101
Dec 21, 2010 | Kenmore Dryers
Dryer starts with the burner coming on then its wont fire again durning the rest of the cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 06, 2010 | Kenmore Dryers
Gas dryer burner intermittently lights. Foul gas
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
I paid to have jahn27 solve my problem with kenmore model 70172 dryer (burner cycles such that clothes don't dry. he recommended replace of both burner coils which i did but burner still cycles). how do i...
heatman101
Aug 11, 2010 | Dryers
Kenmore dryer buzzes but does not run
You could have any one of several problems with that gas dryer -
Turn dryer on.
Go out to where dryer duct exits house.
Feel the amount and strength of air blast coming from vent.
Air blast should be strong and cover the full face of the vent.
If not, check that dryer hose is not crushed/collapsed behind dryer as it is pushed back into position.
Clear any restrictions in the vent pipe.
Clean lint screen.
Check that there is no restriction where air is pumped into or discharges from the dryer drum on the inside.
If you are able to, check to see if you can see the pilot ignitor lighting.
Reply back your findings for further instruction or information.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Make and Model Clarification
Here is the customer contact page. I could not find the model number listed on their website. It may be too old? I have also lost track of your original question, sorry.
http://us.lgservice.com/index_b2c.jsp
Dec 26, 2008 | LG DLG3788W Gas Dryer
Lg dryer - gas
If you do not have the original orifice you will have to order a natural gas orifice and replace the LP one with it. It is just a small brass threaded part with the correct size hole in it, located right at the end of the burner. For a LG dryer it is probably part number 4948EL4001B but you should get your model number from the sticker just inside the door and order the correct part from your nearest servicing dealer. You can find LG servicer's in the US on line at http://us.lgservice.com/index_b2c.jsp
Nov 02, 2008 | Dryers
Dryers Logo
111 people viewed this question
Top Dryers Experts
