Question about Baxter BXA2G Stainless Steel Gas Single Oven
Were is located the thermostate - Baxter BXA2G Stainless Steel Gas Single Oven
  • 43 Answers
The thermostat is solid state, it is incorporated into the control board. You can however locate the temperature probe which goes into the left side of the back of the control board and goes into the top of the oven under a cover near the air pressure switch and high limit thermostat. To locate follow the small aluminum tube coming from your exhaust stack, that will lead you to the air switch which is next to where the temperature probe enters the heat exchanger compartment.
Posted on Jan 02, 2012
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
Miele t8322
I would suggest the limit switch sometimes located on the metal vent tube inside the dryer. The metal tube/pipe that exits out either the side or rear is the one I am referring to, has a high limt switch attached with 2 screws, sometimes this causes an open circuit.
Nov 03, 2013 | Ovens
Oven does not heat to set temperature. Could this be a bad element or the thermostate? Electric single oven, Model# RE537, PT 3497853 Serial# 78093
YOU NEED TO CHANGE THE SENSOR LOCATED IN THE OVEN USUALLY AT THE TOP NEAR THE BROIL ELEMENT.IF THIS DONT TAKE CARE OF IT YOU WILL NEED TO CHANGE THE CLOCK/THERMOSTAT. DO THE SENSOR FIRST THIS IS THE CHEAPEST PART TO CHANGE.
Nov 02, 2010 | Frigidaire Ovens
I have a GEMINI MULTI FUNCTION THERMOFAN EYE LEVEL OVEN. The bottom over is not working. Don't know why. Don't know where the fuses are, if any. What can the problem be?
the elect clock controls the oven and is probley the problem . . some have thermostate's ( saftey ) but in most cases they shut down the complete oven .. mm
Jul 13, 2010 | General Ovens
I cleaned over with self clean and it blows the thermostate. Is this normal on Kitchen aid wall mount ovens?
if u have unproper vent specs on unit it will blow. read instellation spect for proper vent specs
Feb 12, 2010 | KitchenAid Architect Series KEBC177KSS...
Gas oven not reginiting automatically
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jul 18, 2009 | Ovens
Baxter BXA2G Stainless Steel Gas Single Oven Logo
206 people viewed this question
Top Baxter Ovens Experts
Lawrence Oravetz
shannon816
Are you a Baxter Oven Expert? Answer questions, earn points and help others
