Fan runs until unplugged. Why? - Heating & Cooling
  • 59 Answers
The furnace is going into a safe mode. You have one or more sensors out. You need to open the front door of the furnace and check the control board for error signes
Posted on Oct 07, 2010
I"mworking on a frigidaire french door. Model LGHN2844MFO The evap fan would not run until I unplugged unit
Electrical fan motors cannot run without electricity. The fan ran while it was unplugged? Please expand on the problem description.
Nov 01, 2016 | Frigidaire Refrigerators
Why does my fan stay running for more then 90 minutes until the battery goes dead
Radiator fan runs continuously - volvoXC.com
www.volvoxc.com > Forum > The Vehicles > 2001-2007 XC70 (V70XC)
Jul 12, 2011 - 10 posts - ‎6 authors Hi, I have a problem with the radiator fan running continuously. ... According to Volvomechanic, when the pressure in the aircon gas goes ... 2002 xc70 cooling fan stays on
Jul 15, 2012
Blower Motor stays on.
Jan 15, 2011
fan after cutting off ignition?
Jul 25, 2004
More results from www.volvoxc.com
Oct 20, 2015 | Volvo S80 02 2002
How can I get the fan to turn off when the microwave is turned off?
Most GE over the range microwave ovens have a cavity heat thermostat. if the exhaust fan cut on due to external heat generated to oven, the fan will run until unit totally cools down. in this case unplug unit. Also fan can run if you have a broken door paw or if one of the door secondary switches is bad.
Aug 09, 2014 | GE SpaceMaker Microwave Ovens
1992 Ford Tempo Coolant Fan
the "sensor " near the thermostat should have 2 ,3 or 4 wires to it
if it only has one wire , that is the temp gauge sender unit and not the coolant sensor the coolant temp sensor reports to the ecm and that unit then switches on the fan relay that spins the fan
if you unplug the coolant sensor and the fan starts to run you have a serious coolant temp sensor circuit problem
take it to an accredited service center and have it sorted
May 01, 2017 | Ford Cars & Trucks
Cause the sensor is unplugged,can't control it any more,will always run now.
Nov 08, 2012 | Ford Cars & Trucks
Cooling fan runs continuously, even after shutting the ignition off
sounds like it could be a relay.
With everything plugged in and the fans running with the key off remove the cooling fan 1 fuse. Do they stop?
If they do not stop remove the cooling fan 2 fuse. Do they stop?
Aug 15, 2012 | 2002 Pontiac Montana
Coolnet fan doesn't come on. can u plz help
Unplug the coolant temperature connector on the side of the engine above the transmission. Place a jumper wire on the connector that you unplugged. Now, turn the key to run position, don't start the engine though. Listen to see if the fan runs at this point. If it does, this shows that it is capable of running. If it doesn't, you will need to unplug the connector at the fan and supply voltage from the battery to both terminals going to the fan motor. If it doesn't run at this point, replace the fan. Keep in mind that on the Saturns the fan often doesn't come on until the temperature gage is over the half way mark at about 5/8 of the way.
Jul 17, 2010 | 1996 Saturn SL
I have a Luxeon v1 that runs for about 1-2 hours and then shuts itself off. The bulb is off but the fan is still running. I am unable to turn off the projector and I have to unplug it from the outlet to...
First of all, DO NOT unplug the unit until the fan stops. The fan should continue to run until the lamp has cooled down completely. This is normal. If the unit is shutting down on its own, perhaps the fan is not working good enough. Check for debris in the fan area and be sure that there is enough ventilation to keep the unit cool. The shutdown may be a safety shutoff because of heat.
Check the fans and update this with what you find.
Dan
Nov 03, 2009 | Luxeon V1 Multimedia Projector
98 cherokee fan still running
Jul 25, 2009 | 1998 Jeep Cherokee
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
