Question about Whirlpool Duet GHW9150P Front Load Washer
Control Locked release? - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
If you are referring to the Control Lock on a Whirlpool Duet, Kenmore Elite, or Maytag Epic series front loader, this is actually a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
The following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Posted on Oct 07, 2010
The control touch panel is locked in door locked mode wont clear to use other control functions
I appreciate your post, philip hunter!
From my understanding the control panel on your Electrolux range is locked. On the control panel you should see a button near a lock symbol, typically it is labeled control lock, and if you hold that button down for three to five second it should release the control panel. If that does not help release the panel I would suggest performing a reset and you can do that by disconnecting the power from your range for ten minutes. Hopefully this helps. -Matt
Dec 20, 2014 | Electrolux Kitchen Ranges
GHW9300PW4 CONTROL LOCKED
Chek for water in the drum if so take out the filter and clean there will be lots of water so be carefully make sure machine is unplugged from mains
Nov 15, 2013 | Whirlpool GHW9300 Duet Washer
Dishwasher won't run. Message says Control Locked.
push and hold the lock button for 3-5 secs then release
Oct 13, 2012 | Dishwashers
My washing machine machine is saying control locked
To unlock the controls press and hold the "END OF CYCLE SIGNAL" for 3 seconds until the Control Locked status light turns off then release the button.
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
'Control Locked' light, can it be reset easily?
Press and HOLD the lock button for 3 seconds,then release it.
Jul 25, 2010 | Kenmore 45996 Front Load Washer
I have a Whirlpool duet washer and on the control panel the light that says control locked is on and the washer does not work - is there a way to reset it?
Press the Pause/Cancel button twice then press and hold the End of Cycle Signal button for three seconds until the Control Locked light turns off. If it doesn't work, unplug the washer for at least fifteen minutes to reset it.
Replace the user interface/LED assembly if the Control Locked indicator still lights up and not allowing you to operate the washer.
Remove the three screws at the rear of the top panel securing it to the back of the washer. Slide the top panel back and lift it off the washer.
Disconnect the user interface/ LED assembly ribbon connector from the left side of the central control unit (CCU) and release it from the wiring harness brackets.
Pull the dispenser drawer out and press down the release tab at the back of the drawer to pull it out completely.
Remove the screw that was covered by the dispenser drawer in the recessed hole next to the drawer opening.
Open the door and insert a flat-bladed screwdriver into the notch at the bottom center of the control panel to release it.
Press and release the tab behind the right hand side of the control panel securing it to the cabinet.
Gently pry up and release the top of the control panel and pull it off the washer.
Pull the cycle selector knob off the control panel and release the tabs securing the user interface/LED assembly to the control panel. Lift the user interface/LED assembly from the control panel once all the tabs are released.
Install the new user interface/LED assembly into the control panel by inserting it into the tabs from one side to the other until it is completely secured.
Install the control panel on the washer and the top panel in reverse of the removal steps.
Note: Please specify the model number of your washer for the specific replacement parts.
Mar 01, 2010 | Dryers
Locked control panel
I finally got a call from a repairman that said. Hold the options and reset button in at the same time for 30 seconds to release the control panel lock. It worked.
Jan 16, 2009 | Washing Machines
Control panel is locked
HOLD DOWN "clear/off"
Jan 11, 2009 | GE Microwave Ovens
Control locked light
check your panel closly the lower right hand button is marked"control lock" hold for 3 secs and youll release the control lock
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Controls are locked
door locked?? or control locked???? if control locked look to the far rigthset of buttons and the lowest one should say control lock(very small print) or a picture of a loc. hold it in for 305 secs and control lock will release
Mar 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
27 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
