Question about Jenn-Air Kitchen Ranges
I have a Jenn Air S160 stove and the burners stopped working. Is there a reset button? The grill does work on one side but the burners do not. Thanks, Pam
Try switching the grill to the other side if it works the ceramic burner is bad replace the ceramic burner. burners and grill coils unplug when you pull them out. The left one pulls out from the front the right one pulls put from the rear. you can enterchange the burners on either side.
Posted on Dec 16, 2010
My folks recently purchased a house with a Jenn-Air S160 electric grill-range/oven. The left hand side electric burner cartridge's back burner superheats on the low setting. I've switched the burner...
Sounds like the problem is in the control assy. especially if you switched the burnners and the problem remained. Go to the jenn-air website and see if they have a parts breakdown for your unit.
Record the model number of the unit before you search, you will need that info.
Apr 16, 2011 | Microwave Ovens
I have a Jenn-air, C206-C model grill-range cooktop. Three of the 4 burners have stopped working. Any solutions?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 04, 2010 | Jenn-Air JED8230 Electric Cooktop
Stove is tripping circuit breaker Two burners stopped working properly (only get slightly warm). Switched the coils to the other side and the other side is still working. Looked underneath and saw that...
if it is an old stove i would say have it serviced/checked over. if it is a newer stove i am guessing the circuit breaker predates it and is rated for the old stove therefore you will need to have a larger circuit breaker installed (by a licenced electrician)
Mar 04, 2009 | Jenn-Air Expressions AC110 Electric...
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Jenn Air Grill - Gas flow from one valve
I have the same problem. The middle and the right burners will work, but if I light the left side (3rd burner) all 3 go out. pressure is reduced to zero.
Aug 30, 2008 | Grilling
Jenn Air 720-0061-LP Gas Grill Rotisserie Problem
Hi all ,
I just bought a jenn air 720-0336 gas grill from bj's . the rear rotisserie burner would stop working after a few minutes .
hear is the deal , the rear inferred burner gets to HOT . they did not put any insulation between the ceramic blocks and the metal bezel.My fix was to remove the unit , drill out the 8 rivets holding the bezel on , carfully remove the bezel and install a fire proof gasket , i was abile to find the proper stuff at my local coal / wood stove retailer.it comes in a white sheet about 1/8 inch thick .
use steel rivets to reassemble . good luck . this took a week of trial and error to figure out .
Aug 02, 2008 | Grilling
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Tell me what jenn-air model sve47600 10 year old stove is worth
Not sure, but I would be interested in parts if you have any extra. I need a double burner for mine. I have a burner for one side and a grill and steamer for the other. I do not use the steamer but would love additional burners.
Apr 14, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Kitchen Ranges Logo
255 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
