Question about HP LaserJet 4600dn Color Printer
Transfer kit The transfer kit said it needed to be replaced. We were down to 168 pages and no message is showing. I don't see a 'replace toner message either. What do we do?
    Problem Solver:
  • 25 Answers
When you change your Transfer Unit (ETB) Be sure to calibrate your printer, you may end up with the masses of paperjams.
Posted on Aug 14, 2008
    Problem Solver:
  • 33 Answers
The transfer kit is unrelated to the toner. On most printers it gives you the message that it needs replaced after X number of prints. Depending on page coverage and the quality of the paper you are using there may still be some life in it and you can clear the message and print until the image quality is affected then change it.
Posted on May 29, 2008
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
Laser Jet P2015dn only prints in grey not black. Changed the toner cartridge - didn't help. Went into properties menu, looked to see if "econo" mode is on, and that doesn't exist. Help!
Sounds like you might have a transfer roller that needs to be replaced. The transfer roller is under where the cartridge seats and transfers the toner to the paper...If toner is not sticking to the transfer roller it will show what you are seeing....Transfer rollers come in Maintenance kits. If the transfer roller is not the issue....its most definitely the fuser not fusing the toner completely, due to improper heating, to the page giving a lightness.
Oct 19, 2010 | HP LaserJet P2015dn Printer
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Dec 21, 2009 | OKI C9600hdn Laser Printer
Lite toner marks on paper
The imaging drum is included in the toner cartridge on this one, so you could need a new toner cartridge. If that doesn't fix it, then you are looking at either the transfer roller or the fuser needs replaced. Workgroup printers usually require a maintenance kit after 300,000 pages printed, fyi. that kit includes feed rollers, a fuser, and a transfer roller. Not sure what the page count is, but that could help you figure it out.
Nov 03, 2009 | Lexmark T644 Laser Printer
HP4345 MFP printer and the print quality is fuzzy. I put in a new toner cartridge and that didn't work and i also created a cleaning page and that didn't help. what next? just had the tech out here last...
Fuzzy print is mostly related to 3 items in your printer. 1 the toner cart. 2 fuser. 3 transfer roller. A fuser replacement is a normal fix for this problem. Check your PM kit status by printing a supplies status page. A PM kit will have a fuser, transfer roller and feed rollers. If the PM level is low ,order and replace kit. If not you may want to get a new fuser
Sep 23, 2009 | HP LaserJet 4345mfp Printer
Samsung CLP600 - wants me to install a transfer belt
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Mar 31, 2008 | Samsung CLP-600N Laser Printer
Phaser 6250 transfer roller
Hi clwest: I hope that this will help you.
Transfer Roller is at End of Life
■ Print the Supplies Usage page to verify the remaining life and Transfer
Roller install date.
■ Cycle printer power.
■ If the problem persists, follow the procedure below
Note
Look at the clear plastic window on the Transfer Roller. If toner is present in the
center of the window the Transfer Roller is at end of life and needs to be
replaced. If no toner is visible, try cleaning the CTD (ADC) Sensor.
The “Transfer Roller is at End of Life” is a warning. “Replace Transfer Roller” is
a hard stop.
Dec 15, 2006 | Xerox Phaser 6250N Printer
"replace transfer kit" for Konica KL-3015
Hi Hexus, http://www.kmbs.konicaminolta.us/eprise/main/KMBS/Support_Center/Manuals/Pages/Attachments/3015gs.pdf Download that manual the directions with diagrams for replacing the transfer kit are on page 40 (in the page numbers on the docs themselves, the Acroreader page number is 51) Hope that helps, El Duderino
Nov 21, 2006 | Konica KL-3015 Laser Printer
HP LaserJet 4600dn Color Printer Logo
236 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
