On the computer monitor after inicializing it, the following advisory appears; "McAfee Privacy Service Falta un componiente de la aplicacion. Vuelva a instalar Mcafee Privacy Service. Codigo de error (7.1.001) Please assist me to correct this problem. Thank you. t
  • 4,102 Answers
Hi can you press the start button in bottom left hand corner of screen then hit the control panel button then select add or remove programs, then when that screen has fully loaded and you have got a list of all the programs on your computer then look in the list for any mcafee programs and click on them and un-install them once you have done this restart your computer and you should have no problems.
the error you are getting is basically saying mcafee is corrupt this maybe because you have 2 different virus protection on your computer so remove mcafee you can always install it again after, the best ones i use and their free is avg i find its better than most of the ones you pay for, so i would go for that one.
with avg when you search for something say using google and the list comes up it tells you which sites are safe or not so i find avg one of the best free protection you can use as it beats most that you pay for
let me know how you get on ok or if you need further assistance ok
Posted on Oct 07, 2010
La aplicacion pantech home (proceso com.pantech.home) se a detenido de forma inasperada. y dice vuelva a intentarlo. En la parte de abajo de este aviso, tambien aparece un aviso que dice FORZAR CIERRE. Que...
aplicacion pantech home (proceso com.pantech.home) se a detenido de forma inasperada. y dice vuelva a intentarlo. En la parte de abajo de este aviso, tambien aparece un aviso que dice FORZAR CIERRE . Que se puede hacer para solucionarlo
Jan 28, 2013 | Pantech Crossover
Saludos, mi endeavor tiene Una vibracion fuerte cuando va de 20 a 40 millas.
saludos, tengo una mitsubishi endeavor 2005, la cual me estaba dando exactamente ese problema, cuando iba acelerando entre 20 y 40 da una vibracion muy fuerte, el problema esta en la transmision, eso lo causa la falta de liquido de transmision, cuando a la transmision le falta liquido hace ese fallo para indicarte que le falta y que debes completarlo, mi recomendacion es que lo revises lo antes posible y que le heches un aditivo para transmision, hice eso y se le quito inmediatamenteee, cuando la revise estaba seca no tenia casi nada de liquido de transmision.
Feb 04, 2012 | 2005 Mitsubishi Endeavor
Tengo un multifuncional x2600 y me marca error atasco de papel, ojala me puedan ayudar...ya cambie los cartuchos ya trate de sacar una impresion y no me permite hacer nada..
Quite las hojas de papel desde el alimentador. Trate de abrir la tapa de la impresora y retire ambos cartuchos. Mientras que la cubierta está abierta, compruebe si hay obstrucciones en la ruta del carro del cartucho. Compruebe si hay conexiones sueltas. Si todo está bien en el área del cartucho, cierre la tapa. Desenchufe y vuelva a conectar la impresora a la fuente de energía para restablecerla. Cuando la impresora se enciende, vuelva a insertar un cartucho en primer lugar. Cierre la tapa y comprobar que no existen errores. Si no, abra la tapa de la impresora de nuevo y vuelva a insertar el cartucho de otros. Vuelva a colocar el cartucho lo que está causando el error que aparezca. Usted también puede tratar de insertar un cartucho de diferentes conocidos trabajando para determinar si el otro es culpable.
Nota: Esto se traduce con translate.google.com.
May 20, 2011 | Lexmark X2600 InkJet Printer
Buenas tardes me podrian ayudar con una impresora modelo 3100cn , me manda un mensaje 016-317 restart printer
Hola! Realmente es un dolor de cabeza este problema debido a que su sistema,el sistema operativo,siempre reconocera el mismo.Trate de apagar el printer,luego desconectelo de la PC y de la toma de corriente y espere unos 15-20 minutos.Luego vuelva conectar el printer y encianda la PC.
Si esto no le funciona desinstale el printer e instalelo otra vez.Es importante que la desinstalacion sea efectiva y que no quede rastros de los archivos del printer.Recomiendo RevoUnistaller para este proceso.
Si aun tiene problemas vuelva.
Suerte!
Jan 27, 2011 | Dell 5100cn Laser Printer
`LA IMPRESORA HP DESKJEST F380 ME MARCA ERROR Y NO ME IMPRIME
Use este enlace y baje la aplicacion.Luego habra la aplicacion.Esta le dara un diagnostico de su problema.
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English) .
Si necesutas mas ayuda vuelva.No ovide dar un "thumbs" o algun testimonio de mi solucion,gracias.
Nov 18, 2010 | HP DeskJet F380 All-In-One Printer
Mi toyota 86 no inyecta gasolina, da chispa pero no inyecta
Pareciera que los inyectores no se estan diparando, ya sea por falta de corriente, o por falta de la orden de la computadora, que sincroniza la abertura momentanea de cada inyector. Haz que alguien intente prender el motor, mientras tu pones el oido cerca de un inyector, o le pones el dedo encima. Deberias sentir una rapida secuencia de clicks. Algo mucho mas complicado es sacar un inyector, sin desconectarlo, y ver si dispara el chorro de gasolina cuando intentas encender el motor.
Jun 21, 2010 | 1986 Toyota Pickup 4WD
Se me olvido la Clave del router
Si te olvidaste la clave del router, proba usando la original de fabrica del router:
D-Link
usa esta direccion de acceso http://192.168.0.1
- user=admin
password= (sin password, en blanco, solo pulsa enter)
(generalmente son (admin, password) y mira que pasa (si es que no la cambiaste)
Al resetear el router volvera a su configuracion inicial y perderas la informacion que tenia configurada. Antes de resetear podes tirar un ip config saber tus ip adresses.
Ahoras si te olvidaste la clave de acceso a tu network, podes obtenerla con cualquier aplicacion de password recovery.
Oct 24, 2008 | D-Link DI-808HV Router (280006OB)
Pixma MP160 not faxing
ERROR E27
Hola gente no lo consigo ni por un lado ni por otro.
Alguien lo ha conseguido ???
Sigo las instrucciones al pie de la letra:
Describo las teclas que he usado:
parar -> tecla en roja que tiene un circulo y dentro un triangulo
on/off -> tecla que pone on/off arriba
1- Pulso y mantengo pulsá la tecla de parar
2- pulso y mantengo "on/off" y suelto parar
3- teniendo pulsada "on/off" pulso dos veces para y en la segunda suelto para y on/off
4- la impresora se enciende y pone un cero en el contador
5- pulso una vez la tecla parar se enciendo la luz de la izquierda que es naranja la que esta con el triangulo y un rayo dentro
6- pulso otra vez para y la luz se va a on/off
7- pulso para otra vez la luz pa la izquierda es decir triangulo y rayo
8- pulso otra vez para (ya van 4 veces) y la luz pasa a on/off
y ahora que....
por que yo pulso ahora on/off y la impresora hace ruido pero la apago la vuelvo a encender y las luces de falta de tinta, es decir la de la B y la C siguen encendida
no se que hacer he mirao por todos los foros del mundo estoy a punto de tirarla por la ventana y comprarme otra
saludos
Apr 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
