Question about Brother HL-2040 Laser Printer
New toner cartridge but prints way too light
I have tried 2 new Brother cartridges, but the print is still very light (hard to read). There was no problem with the first toner cartridge. I bought printer about 3 months ago. Thank you.
  • sparketta May 29, 2008
    Hello and thank you. The cartridges were new and the actual Brother brand, and the printer is only 3 months old and not used heavily. Any other ideas?
    Problem Solver:
  • 33 Answers
Where they refilled or third party cartridges? If so try a name brand. It could be the high voltage board or the laser aperture
could be dirty.
Posted on May 29, 2008
  • gerald Hartman May 29, 2008
    unless you are in a dusty environment it shouldn't be an aperture
    issue in just 3 months. It is probably in the board containing the high voltage parts. If it was HP I could give you details.I am HP certified. If it is only 3 months it is still under warranty they shoud replace it or send out a factory technition at no cost to fix it. Do not open it yourself that will violate the warranty.
    Thanks
    Gerald
Brother 1510 replace toner problem
Assuming you have tried to replace an empty toner with a new or refilled toner cartridge. Some of these machine simply fail to recognise the reset activation lever on the side of the cartridge. You could try removing the end cap at the geared end. You will find a half moon shaped gear which needs to be lifted out slightly and rotated a quarter turn clockwise. replace any other gears and refit the cover. This resets the toner cartridge to "new" state. If you printer doesn't recognise this, you will need to get a manual reset keycode from brother. Please note - some folk reset used cartridges this way and re-use them. Used toner will contaminate the drum and give poor print. Any residual contaminated toner on the drum can contaminate a new cartridge and so-on. Refilled cartridges are fine if the cartridge is completely cleaned out first.
May 06, 2015 | Brother DCP-1510 Laser Multifunction...
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
Toner light is on and wont print
How new is your cartridge? Usually when the cartridge is getting close to empty the print comes out light. You can try shaking the cartridge gently from side to side to distribute the toner throughout the cartridge.
If you are in need of getting a new cartridge, try a compatible. I have had great luck with them, and the save you lots of $ and work just as good.
I purchase all my toner and compatible cartridges from:
www.lasertekservices.com
I hope this helps :)
Apr 30, 2010 | Brother HL 5140 Laser Printer
Brother Printer 2150N - toner light has come on & toner is OK
Bought a 2150 in 2007. In 2008 toner light came on. Bought a new toner cartridge and installed. Light would not go off. Called Brother. They had us do the following:
1) Turn power off
2) Open front cover
3) Press white button (left side) 2 times and hold
4) Turn power on
5) Press white button 6 times and hold. All 3 lights should come on.
6) Close cover
7) Press blue button 3 times. Should print demo page.
We took the new cartridge out and saved it. The original is still working fine.
Feb 24, 2010 | Brother HL-2150N Laser Printer
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Apr 24, 2009 | Office Equipment & Supplies
Toner quality is still light after installing new toner cartridge
No, if the old one prints better than the new ones, it is a toner cartridge problem. Are they remanufactured /compatibles? I suspect it is a problem from the supplier
Mar 09, 2009 | Brother HL-2040 Laser Printer
Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge2_bing.gif to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Feb 11, 2009 | Brother HL 5250DN Laser Printer
Brother HL 2140: Toner ledlight lit, stopped printing. Cleaned Coronary Wire. Toner Cartridge new - 2 weeks old.
Hi Adsl34xg,
The cartridge that comes with the printer (or starter cartridge) has a yield of 1,000 pages @ 5% coverage. It probably really has run out of toner. Replace with a new cartridge to see if you can print. A replacement cartridge should give you 2,500 pages @ 5% coverage.
Dec 17, 2008 | Brother Office Equipment & Supplies
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-2040 Laser Printer Logo
142 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
