Question about GPS
Unit will not come on green light is on and is docked to computer
  • Anonymous Jul 28, 2008
    Unit's only 25-days old. Got into my car this morning and the unit is as dead as a doornail. Still attached to lighter socket in car which is glowing its normal bright blue...
    Depressed on/off button for short and extended periods. Nada!
  • Robert O'Neill
    Robert O'Neill Aug 12, 2008
    green lightis on but tomtom will not power up
Tom tom kicked reset button[510]called customer assistance. use paper clip bent to a point turn unit upside down so ser# can be read you will see one gold ternimal on left side and about a dozen small terminals to the right just above last three terminals is a notch in plastic cover reset button is in middle of slot push with paper clip two or three times not overly hard.mine started working.when plugging to cig. lighter button kicked.easy fix hooray for TomTom.hope this helps.greetings from Music City.
Posted on Jun 16, 2008
How do i update my tomtom?
1) Install "TomTom Home" software in your computer from www.tomtom.com
2) Start TomTom Home in your computer
3) Plug in the GPS2_bing.gif dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
4) Start your GPS while being in the dock. If the GPS asks "do you want to connect to computer" answer "YES"
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. You choose the ones you want to install.
Please, report back if you need further assistance
My ID: alexocuello_
Mar 25, 2010 | Tomtom ONE XL GPS
My tomtom one gps can't get signal
When was the last time you updated the QuickFix of your TomTom? It helps your GPS to find the satellites.
Please, do the following:
3) Plug in the GPS dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. Be sure you choose to update "QuickFix".
My ID: alexocuello_
Mar 19, 2010 | Tomtom ONE GPS Receiver
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell latatude D630 is docked/battery flashing 4 red 1 green
4 orange and 1 green can mean a battery malfunction, or it could be an indication that the battery is about to reach the end of its life cycle. When a battery is built, it has a planned expectancy. a date code is stamped in the electronics of the battery pack. as that date code is reached, the indicator lights on the computer let you know the battery (even if its working fine) is considered obsolete and needs to be replaced soon.
Nov 05, 2009 | Dell Latitude D600 Notebook
Kodak V530 won't upload pictures from docking station to comuter.
If your camera have a sd/mmc card just buy a sd card reader and plug it in your pc. it will transfer all your pictures to your computer.
user guide for your camera
http://support.en.kodak.com/app/answers/detail/a_id/18624/~/kodak-easyshare-v530-zoom-digital-camera%C2%A0%E2%80%94%C2%A0users-guide/selected/true
Jun 10, 2017 | Kodak EasyShare V530 Digital Camera
My tomtom 510 was working fine until this morning when I set it in it's windshield dock. The green light to show that it's charging came on but nothing else. It's been on the charger all day but won't...
Remove the docking foot from the unit and expose the docking connectors. The reset button is at the bottom left of the body next to the connectors. It's hard to see but a paper clip will do the trick. Push just hard enough to here it click. Now it is reset.
Jun 25, 2008 | GPS
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
"check connections"
I am having a similar problem. I put mine in its dock, connected the USB cable to my computer, and pressed the USB button on the dock. The light turned green and after 30 or so seconds, the message Check Connections came up on the camera.
Apr 24, 2007 | Casio Exilim EX-S500 Digital Camera
GPS Logo
105 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
