Question about Sebo Vacuums
Sebo automatic x4extra 1300w
Hoover will not starrt flashes red on check brush and bag full or clog what other fuse does it take besides 10amp
  • 1,673 Answers
Check for any blockage in the hose or the inlet by the brush roll. Is the brush roll jammed? There are 2 circuit boards, one for the 12V power supply and the other is the computer controller, one of these may have gone bad.
Posted on Jun 01, 2008
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
No power but lights flash
Is there a reset switch. Most vacuums have one some where near the bottom brush, to protect the vacuum from overload. If the vacuum tripped, the vacuum will not work until you've pressed the reset switch. If you can't find one, pls check manual.
Mar 04, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Light on for "full bag or clog." I changed bag,
Check the airflow tube behind the brush. This is a common place for clogs. The hose is more common, especially at elbows, like where it attaches to the tank. Another possibility is a dirty filter. Check this first to rule it out, then check the rest.
Jan 26, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X1 - Doesn't work although there is power
I'm not sure about this one but, as nobody else has picked it up, I'll give it my best guess. You say the machine just hums - by which I take it that there's no suction at all. I wonder how old your Sebo is... if it's seen a lot of work, it's more than likely that the carbon brushes in the motor have worn out and need replacing. This is not a difficult job, but you do need to be comfortable tinkering with machinery to attempt it yourself. Otherwise you will need professional help. If you want to do it yourself, post a reply here and I'll give you step-by-step instructions.
Apr 21, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
No motor when switched on and 2 red lights flash
Your Sebo has switched itself off to prevent damage. The flashing red lights indicate that the brush roll is jammed and that there may also be a blockage somewhere. You should take the brush roll out and make sure it is clear of obstruction, and also check for blockages (in the inspection flap on the underside, and in the plastic pipe and the flexible hose), and check the condition of the filter in the bag compartment. If the brush roll is clear and the problem persists, you should seek help from a professional repairer as something is probably broken inside (although with Sebos this is extremely rare). Good luck!
Jan 29, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
The red light on the cleaner keeps coming on. I
It could be clogged or there is a sensor adjustment for this machine and it takes a very small screw driver to adjust it. Take it to a certifies Sebo dealer and he can fix it in just a minute.
Nov 26, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X14 -red light comes in for clog or bag full. , bag is new. Cleaned out all clogs
Unless the circuit board is bad, you still have a clog, Either in the hose, or the dirt inlet by the brush roll.
May 05, 2008 | Sebo Vacuums
Vacuums Logo
205 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
