Question about Toshiba E-STUDIO 550 Copier
Tips on C26 code , more info how to fix - Toshiba E-STUDIO 550 Copier
  • talat_hussai
    talat_hussai Aug 08, 2012
    lamp on and working but errors still
  • talat_hussai
    please tell me where is slg board
  • Toshiba Master
  • 643 Answers
[C26] = Peak detection error
Does the exposure lamp light? (Perform the output check in the test mode: 03-267)
If no, Replace the SLG board-->inverter-->exposure lamp.
Posted on Oct 09, 2010
Strip is ok and lamp light is on but still c26 error appears
Posted on Aug 08, 2012
Reset spanner error
There are several error you need to know the sub code by pressing c and 8, frequently you may come across the error code C44,C97,C26
.For C44 the error clearance is "switch on the copier while pressing 0&8 AD will appear enter 400 and press start (print) button and enter "0" and press Interrupt button , switch off and on the machine .If the error code is C97 the main charger to be cleaned in drum unit, If it is C26 you need to check the scanner cable..Hope the anser.
Jun 11, 2014 | Toshiba e-Studio163 Copier
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
E 207 errors
It might be C97 or C26 Clean drum unit and transfer charger. For C26 check scanner cable.
Sep 27, 2013 | Toshiba Office Equipment & Supplies
Toshiba E-studio 166 error code c26
hi. i have problem in my Toshiba e studio 166. that machine toner light is blinking always. i try so many time nd i fixed new toner also. but i cant get any result of this. pls help me to solve this problem....
Mar 07, 2012 | Toshiba e-Studio163 Copier
What is the solution for error code c26 on my toshiba e-studio 550 copier?
Hi how are you i hope you are well this is jack ..my personal ID.. (jack_pak@hotmail.com)
C26 Error is scanner error
please check the scanner unite
1 scanner lamps.
2 scanner strip.
3 scanner bord
4 LGC bord.
please check these all goods are working properly.
Thanks
Best Regards,
Jul 02, 2010 | Toshiba E-STUDIO 550 Copier
Call for service c26 in toshiba copier e 810
C26 indicates Peak detection error.
U need to make sure the exposure lamp is light when u switch ON machine.
If no light, then u need to check the inverter and the exposure lamp.
Oct 06, 2009 | Toshiba E-STUDIO 650 Copier
Help
C26 is a peak detection error (when the copier scans the white reference plate there is an error in the detection)
The most common cause of C26 error is the failure the lens unit which is Toshiba's part number 6LA02100000.
The components that fail on the board are IC1 and IC10.
The board can be repaired, but most commonly it is replaced.
May 05, 2008 | Toshiba E-STUDIO 650 Copier
Help me
A C26 code is a peak detection error on your scanner. You'll have to turn off the copier, remove the glass and CAREFULLY clean the mirrors and exposure lamp on the scanner. That usually takes care of the problem.
Apr 08, 2008 | Toshiba E-STUDIO 650 Copier
Erro code c26
C26 indicates Peak Detection Error.
U need to check whether the lamp light on when u ON the machine.
If no, u need to check the inverter cable, inverter board, or exposure lamp.
If light is ON, then u need to perform following:
1. Check if the connectors on the CCD and SLG boards are disconnected.
2. Check if the shading correction plate is dirty.
3. Check if the conductor pattern on the CCD board is short- or open-circuited.
4. Check if the conductor pattern on the SLG board is short- or open-circuited.
5. Replace the lens unit.
6. Replace the SLG board.
720 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
