Question about Kenmore Elite 45986 Front Load Washer
I have a kenmore elite H3T front load washer, it's flashing F35 and I don't what it is. It doesn't reset, what do I do
    President:
  • 1,430 Answers
If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked
Check the drain pump filter for debris
If all the above checks out good . This would indicate that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. Here is a link to help with accessing the pressure switch also if you need diagrams or illustrations of your particular model.
Posted on Oct 07, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
My new kenmore washing machen is not working it shows F35
you need a new pressure switch more than likley its flashing sud before giving you a f35 too right?
that is a very comon problem with the steam washers
if you take the lid off and look to the rear right you will see it
it is small black and dark orangish redwith a hose attached to it
Aug 23, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore Elite...F35 keeps flashing..what does this mean. Please help
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(&^%#
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE 5T Steam Front Loading Washer keeps flashing the code F35. What does this mean? It is not in the manual.
May 02, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
The washer stops and flashes f35 and some times
F35
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Good luck
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
F35
f35 and sud replace your pressure switch
Jul 02, 2009 | Kenmore Elite 45986 Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
47 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
