Question about IBM Infoprint 1130 Laser Printer
Printer starts out print at normal speed than slows after 20 or so pages
    Problem Solver:
  • 10 Answers
Possible overheateing so slows to cool down
Posted on Oct 07, 2010
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
The printing speed slowed to a snail pace. I pressed Setup, 2, and then 6 to print a self-test report. I got a a "cartridge error" message. Then I removed both cartridges and cleaned them. Still...
This is caused by the failure of one of your cartridges. Remove the black cartridge and print a test page. Does the printer print at normal speed? Is so the black cartridge was the issue and should be replaced. If not then put the black cartridge back in and remove the color cartridge and print test page. If the printer now prints normal speed the color cartridge was at fault and needs to be replaced.
please vote for better sharing.. thank you and good luck
Nov 24, 2010 | HP Officejet 5610 All-In-One InkJet...
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Slow prints
it may be a memory size issue check or buffer size...
good lock
Apr 01, 2009 | Konica Minolta DiALTA Di200 Copier
Printer goes into super slow motion when printing .pdf's
Try this --- Double click printer>Choose Printer from menu bar>Select Properties>Click Advanced Tab and make sure "Spool print documents and Start printing immedialety is selected>Click Apply Button.
Jan 29, 2009 | HP Officejet 5610 All-In-One InkJet...
C6180 printing slow
This could be from the image you are printing. If you are printing from a computer or memory card, the dpi (dots per inch) may be higher than some.Standard printing is typically 400dpi, and you can change the settings on your computer or the printer directly. Memory cards and some photos from your computer may be 600dpi and will likely take much longer to print since there is more "color information" that it is trying to fill.
Let me know if this helps.
Jan 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Slow Printing
it may just be a slow printer head, maybe an upgrade is in order. look on the box for page printing speed.
it may also be that you have the resolution set too high for basic printing. try turning this down slightly.
hope this helps.
kev
Oct 03, 2008 | HP PSC 1350v All-In-One InkJet Printer
Brother MFC 210C Printing slow
You may have already tried but /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} From page 129 of the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Changing the printer driver setting may improve the print speed.
Highest resolution needs longer data processing, transfer and printing
time. Try the other settings of quality in the printer driver ‘Basic’ tab.
Also, click the ‘Settings’ tab, and make sure you uncheck the
True2Life®.
Borderless printing is slower than normal printing. If you want to print
more quickly, set the Borderless feature off.
Aug 30, 2008 | Brother MFC 210C All-In-One InkJet Printer
Konica Minolta PagePro 1350W low print speed
Jacques,
Print speeds will vary based on a lot of factors. First thing to note is that your printer should have a first print time of about 20 seconds. This means the first page should take about 20 seconds before it starts printing and than will print at rated engine speed.
Secondly, depending on the type of paper and thickness your speed may slow down. Most printers will slow down for a thicker paper. In general the thicker the paper the more time it needs for the toner to fuse or melt to the paper.
The size of the paper will also greatly affect the speed too. Manufacturers spec their machines to letter size in the portrait orientation (the leading edge is the 11 inch or long side). In general for legal you will have a 15 to 20% reduction in speed and for 11 x 17 you can have as much as a 40% or more reduction in speed.
Print resolution may affect the speed. Usually most printers will print faster in a draft mode. This may also reduce the amount of toner used.
How do you connect to your printer? Different cables all have different speeds. For that matter is there an upgrade to the RAM? This could also change the speed of the print job. However these should not affect the final speed too much.
So to get the "rated" speed of your printer you will need to use standard letter paper with the long edge leading. Remember don't use thick paper and use a draft mode or lower resolution if possible to get the best speed.
I hope this helps.
Henry
Jun 02, 2008 | Konica Minolta PagePro 1350W Laser Printer
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
IBM Infoprint 1130 Laser Printer Logo
44 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
