Question about Linksys Wireless-G WRT54G Router
Used router, so the wireless is already setup with a newtork password. is there a way to reset the network password or setup? the friend who gave me the router is no longer in the country, and so I cannot get the password.
  • 77 Answers
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Posted on May 29, 2008
    Problem Solver:
  • 8 Answers
There should be a reset hole in the back of the unit. While powered up use a pin to hold this button in for about 5 seconds. Once you have reset the unit you will need to hook up to the router through one of the 4 switch ports. The default for the router should be set to DHCP so it should give you an IP address. If you do not manually set you ip in the range of the router. Once this is done use your browser to go to the IP address of the router usually 192.168.1.1. or .254. The default username is blank and the password is admin. Need anything else let me know
    Brigadier General:
  • 6,966 Answers
Most LinkSys Routers do have a master reset. It is a small recessed button normally at the rear of the unit between one of the antennas and the WAN/Internet port. For a full reset, you need to press this for more than 10 seconds. Of course doing a full hard reset reverts the unit back to factory default.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Router pasword
Hello.
- Do you need the wireless password or the router login password?
If you need
wireless password(security key like WEP or WPA) or you would like to setup wireless security for your Netgear router, access the router setup page by typing http://www.routerlogin.net or 192.168.1.1(sometimes it's 192.168.0.1) in the address field of your browser and then press Enter.
Enter
admin for the router user name and your password (or the default, password).
- This image is the login window to access the router's setup page.
- After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the Wireless Key(For WEP you need Key 1,2,3 or 4 whichever is selected... For WPA you need passphrase) or you can setup wireless security from there if you haven't done so.
- This image is the router's setup page and this is where you can configure the router and check some settings like Wireless security or password.
**If by chance you are unable to access the router's login or setup page by using the default username &password(admin, password) and you totally have forgotten it, you need to reset the router to factory or default settings then you have to setup the router again.
**To reset the router to default settings:1. Unplug all the cables attached to it except the power cord.
- Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
2. Once the lights are stable, connect 1 computer or laptop directly to the back of the router(Ethernet/LAN ports usually they are labelled by numbers and have the same color, just pick one). If you pick number 1, check the corresponding light indicator at the front panel of the router, make sure light 1 is also lit up if not choose another port at the back of the router.3. Setup and configure the router again.
~~ Hope this helps ~~
Dec 11, 2011 | NetGear Computers & Internet
I have netgear wireless router. My grandchild friend brought over her laptop and connected wireless. Now it comes up her name. it used to say netgear 5. then it asks for WPA password
Sounds like someone renamed the router and gave it a password from within the Router settings. You will need to ask the people that were messing with it what the password is. Or you could do a factory reset on it to remove the password. Note: It is best to have a password for it in order to connect to it. Otherwise others will be able to connect to your network, like neighbors and such.
Aug 11, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a new lap top which is recognising the wireless network and then asking for a network security key. How do I find this?
The network security key is essentially a password that was setup to control access to your network. Presumably, when you set it up you gave it a password that you could remember, but not so obvious that people could easily guess. If you've forgotten or lost the password, you can reset the router by using a paperclip and holding the reset button for about 10-15 seconds. Once you reset the router, it will be restored to its original factory defaults and you can then setup again your wireless networking.
Jun 20, 2011 | D-Link AirPlus DI-524 Wireless Router
Where is my network security key
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab under the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security key.
7.Always select Security Mode as WPA2 PERSONAL.
8.If you want to change the security key you can.
9.After changing the settings Click on the sav settings.
Regards:-
Amit Awasthi
Dec 09, 2010 | Linksys Wireless-G WRT54G Router
I need to connect ThinkPad R60 to my wireless network. I am used to a computer that just connects on its own. Not sure how to connect this one.
place the mouse cursor over the bottom right screen, you will see an icon 2q==
select it and right click , go to OPEN NEWTORK .. i assume you have high speed modem thats linked to a a router -- select YOUR newtork name -- the others are surrounding neigbours that are close proximity to your network. you will have to know the password or key to enter
if you dont know that get in contact with your ISP and get them to help you connect
please post a positive feedback response for me
Oct 17, 2010 | Lenovo ThinkPad R60 with Wireless Wide...
I gave away my computer with the security code form my linksys and now have a new laptop for which i want to use the router. How can I get the security code?
Hi Friend,
Please follow the steps:
1.Click Start>Run>type cmd and hit enter
2.Type ipconfig/all and hit enter. Note down the default gateway.
3.Type the defualt gateway number in the web browser and hit enter.
4.If you have not changed the router username and password, then type admin in password and leave the username blank.
5.In the router setup page, click Wireless and then click Wireless Security.
6.Since the security is already set, you will be able to view the network shared key, jot it down and you can connect your another laptop.
Regards
Chiranjeet
Oct 12, 2010 | Linksys Wireless-G Broadband Router
My mom gve me a Wireless-G access point Linksys
I suggest resetting the router to the factory defaults by holding in the reset button located on the back of the router for 30 seconds.
The router will reset to the ip address of 192.168.1.1 and you can log into it using either a blank username and the password admin or using the username admin and the password admin.
Please let us know if the above was helpful and if there is anything more we can do to resolve your issue. Thank you.
Sep 16, 2009 | Linksys Wireless-G Broadband Router
Just received the WRT54G router and wireless card from a friend...the router works, but I can't get the wireless to work without the original password, however my friend can't remember it. Since i have...
You can reset to default factory settings.
check here for a full list of default password
or follow these instruction:
"f you have forgot the default password of your linksys WRT54G router than remember that the default password for WRT54G is user name = not required /give any
password = admin
and the default access IP of WRT54G is 192.168.1.1"
and here for a configuration tutorial of your device.
Of course resetting values you have to recreate network configuration this tip can help.
Aug 02, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Zyxel wireless router password
hi . do you guys cant access to your wireless router ? if yes than try this
reset your modem by pressing reset button on your modem for more than 5 seconds so all the information entered will be gone including your password
than insert your modem CD and connect to your modem
set up your internet again
put your password and user name that your ISP gave you
set : get IP from ISP
get DNS from ISP
APPLY
than go to wireless setting
use wpa- personal
and set up a new password eg. (usa2008)
than it will say your computers and network setting doesnt match
go to connect find your modem
right click on it
click on properties
than go security
choose WPA- personal
TKIP
and your password (usa2008) you set to your modem
connect to your internet
im not sure if this is what you mean / thats how i anderstood your problem
NOTE : RESET YOUR MODEM IF YOU HAVE ALL YOUR INTERNET SERVICE INFORMATION
BECAUSE IT WILL DELETE ALL INFORMATION IN YOUR MODEM including user name / password / IP / DNS / and your modems password
Aug 17, 2008 | Zyxel Prestige 660HW Wireless Router...
Need Username and password to setup
it's unusual for a default password to be used bur tr typing 'password' as the password
Apr 01, 2007 | Actiontec GT704WG Wireless Router...
Linksys Wireless-G WRT54G Router Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
