Question about Shure LX-2 With SM58 Professional Microphone
I need to learn how to disassemble this mic. Please tell me how to take it apart. Thanks
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
On the LX2, follow these instructions:
1) unscrew the microphone cartridge
2) Pop off the switch actuators
3) remove the C clip that was under the mic cartridge
4) The circuit board slides out the top.
Posted on Oct 08, 2010
Testimonial: "Thanks, very helpful."
When I key the mic up it turn off and then comes back on
Have you tried to look at mic pins where the mic connects to radio?. it will be at the end of mic connection..look in there and see if the copper pins have spread apart. you will be able to tell by looking at the other pins. if one is spread apart it wont make a good connection and shut things down. be sure when you screw this back on to radio it is tight., if you dont have copper pins just straight pins check to see if the straight pins are not loose. if they are you will need to solder them back tight.other than that it could be your radio..hope this helps.
May 28, 2016 | Radio Communications
Please can you tell me the difference?
The microphone preamps are different. The Xenyx has lower noise mic preamps.
Nov 04, 2013 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Dell a425 disassembly
I found this URL for you that shows a Dell forum where you could probably get all the info you need. It also has specifications for all the internals should you need to replace something. Good luck and be safe. I learned to hate capacitors a long time ago. :-) http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_E876EF53BCA3F058E030030ABD6260B2&isLegacy=true
May 23, 2012 | Dell Zylux Powered Subwoofer - P/n A425
Hello, My acer 4520 laptop mic is not working suddenly. In control panel it is showing working. But I cant use it in Gmail. Ins skype it is working but voice is too low.. How could i test my mic. Its...
The mic is build-in, of course, it's in the top bar of the screen, besides the camera.
You need to be closer to the laptop to get higher voice.
While it works in Skybe, this means it should word in any other program like GMail, MSN, or even with the default recorder comes in windows, some configurations should be fixed or modified in the GMail program
Please tell us your results
Good Luck
May 13, 2011 | Acer Aspire 4520-5582 Notebook
DeWALT dw317
Two chooses:
1) you bring it to a Dewalt service center and have them do it. They will give you an estimate up front with a five or ten dollar inspection fee.
2) disassemble the unit and look for the broken part. It should be fairly obvious once you take it apart. Total disassembly of the unit is the only way to find the problem piece. Use your diagram to ensure the correct reassembly and as a added measure you can take pics with a digital camera while taking it apart. Note getting the wire routing correct when reassembling the unit is the toughest part so, take pics or notes where the wires run.
Apr 03, 2009 | Dewalt compact Jig Saw kit DW317K
Nokia 6126 microphone
it's not to clear which problem u actually had. since it seems like u emphasize 'when i put them in loudspeaker' , does it mean u can also hear them on normal speaker or not? when u say once a week it blanks out (do u mean the mic and speaker problem disappear?).
well both problems has the same solution, but different place to solve.
Start with warranty, u said that u only had the phone for a year, if it still got warranty, bring it to nokia service center, end of story.
if it's out of warranty. u might take it to technician to replace mic and speaker (or juz mic?)
or u can also replace it urself (which i don't suggest, cause you don't wanna broke ur phone'spart accidentally), u just need to learn how to disassembly (open part) your phone, the location of your mic, and replace it. sounds easy huh?
Nov 13, 2008 | Nokia 6126 Cellular Phone
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
I have a audiovox 6700 with screen problems.
PPC6700Users.com has a great disassembly thread in their forum.
If you want a new screen, http://www.pocketpctechs.com/ has just what you need.
Oct 27, 2007 | Audiovox PPC 6700
Mic not working.
It worked well for me too! Thanks Fixya.com!! I was told I had to buy a new phone because the microphone went back. Took the receiver apart (4 screws in back of handset and 2 that held the board in place), cleaned mic with alcohol and a q-tip, and removed the rubber piece that kept the mic clean (inside of the housing), and presto, it worked just fine. The ribbon cable came loose upon opening up inside of phone, but I stuck it back inside the top of base and I was ready to go.
Oct 29, 2006 | Uniden DCT646-3 Cordless Phone
Shure LX-2 With SM58 Professional Microphone Logo
571 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
