Question about Cisco SPA504G IP Phone
How do you make a background picture show up on a Cisco 504G phone. The online Config Utility asks for a Bitmap URL and I found one online that I liked, the only thing on the page is the picture, but it does not show up on the phone no matter what I do. I am using a Hosted PBX (SIP) vendor.
You need to make the bmp file the correct format
128 x 48 pixels 1-bit deep
Simply upload this to a webserver and point the backupground url at the address.
www.mpbtech.com
Posted on Apr 11, 2011
Cisco 504g will not power up
Plug out the cable from this and put in again or reset the device.
May 08, 2014 | Cisco SPA504G IP Phone
My x3-00 has this code: 352008042729464 I need a restriction code for this phone
hi restriction codes is nothing but the code which is used to remove the lock in your mobile.
there are many online sites found nowadays that provide the unlock codes .i got the unlock codes to unlock my mobile
from here mobileunlocksolutions here they ask the following details before providing the codes they are mobile model,country and the provider to which the mobile
is locked .finally they ask the imei number of the mobile .after that they send you the codes to unlock your mobile.
div,ul,li{margin:0px;padding:0px}#abgc{height:15px;left:281px;overflow:hidden;position:absolute;top:0;width:77px;z-index:9010}#abgb{height:15px;position:absolute;left:0;margin:0}#abgs{height:15px;margin:0;position:absolute;left:0px;overflow:hidden;display:none} hi restriction codes is nothing but the code which is used to remove the lock in your mobile.
ad_choices_i.png ad_choices_en.png var abgp={el:document.getElementById('abgc'),ael:document.getElementById('abgs'),iel:document.getElementById('abgb'),h:'281',s:'223'}; body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; }
Sep 22, 2011 | Nokia Cell Phones
We cannot get the 504g will not broadcast its caller ID. it only shows 'restricted'. why won't it display correctly.
change the configuration in your IP Phone change the setting to allow broadcast caller ID .
May 12, 2011 | Cisco SPA504G IP Phone
The router starts and finish POST then decompress image file from flash memory then shows this message: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1) Technical Support:...
I don't really know what your asking but i guess you want to know why your startup-config doesn't load. What your router is displaying is normal. You need to change the configuration register.
1.Let the router load then if asked select Yes to abandon autoinstall, then select No to skip initial setup. Press return (enter button) when asked.
2. Now type the following at the prompts. (you type the bold stuff press enter after each command)
router>enable
router#conf t
router(config)#config-register 0x2102
router(config)#exit
router#reload
........save changes blah blah blah.. type NO
continue with reload Yes
providing you have a startup-config, the router will now load it on bootup.
Hope this helps
Pokeabeaver
May 12, 2011 | Cisco (1841) Router (cisco1841)
Need some basic show command to troubleshoot
mode exec user Router)
ping ip
show ip route
show version
traceroute ip
mode exec priveligiado
show arp
show interface
show protcols
show ip protocols
show startup-config
erase startup-config
reload
Jul 27, 2010 | Cisco ASA 5520 Firewall
No dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Jul 23, 2010 | Cisco SPA504G IP Phone
Hi i have 1841 router what is the default user name password for this i tryed with user name passowrd as cisco but is saying that no user cisco pls help me
  • Follow these steps in order to recover your password:
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
      Use these terminal settings:
      • 9600 baud rate
      • No parity
      • 8 data bits
      • 1 stop bit
      • No flow control
    2. If you can access the router, type show version at the prompt, and record the configuration register setting.
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    3. Use the power switch in order to turn off the router, and then turn the router back on.
      Important Notes:
      • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
      • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    6. Type reset at the rommon 2> prompt.
      The router reboots, but ignores the saved configuration.
    7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
    8. Type enable at the Router> prompt.
      You are in enable mode and should see the Router# prompt.
    9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
      Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
    10. Type show running-config.
      The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
    11. Type configure terminal.
      The hostname(config)# prompt appears.
    12. Type enable secret password> in order to change the enable secret password. For example:
      hostname(config)#enable secret cisco
    13. Issue the no shutdown command on every interface that you use.
      If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
      Router#show ip interface brief
    14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
      hostname(config)#config-register 0x2102
    15. Press Ctrl-z or end in order to leave the configuration mode.
      The hostname# prompt appears.
    16. Type write memory or copy running-config startup-config in order to commit the changes.
Jul 02, 2010 | Cisco (1841) Router (cisco1841)
CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Jan 07, 2010 | Cisco 7941G IP Phone
Cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
Nov 30, 2008 | Computers & Internet
Catalyst ws-c2926 password recovery problem
  1. Attach a terminal or PC with terminal emulation to the console port of the switch. Use the following terminal settings:
    9600 baud rate
    No parity
    8 data bits
    No stop bit
  2. Unplug the power cable.
  3. Hold down the mode button while reconnecting the power cord to the switch. You can release the mode button a second or two after the LED above port 1x is no longer illuminated.
    The following instructions appear:
    The system has been interrupted prior to initializing the flash file system.
    The following commands will initialize the flash file system, and finish loading
    the operating system software:
    flash_init
    load_helper
    boot
  4. Type flash_init.
  5. Type load_helper.
  6. Type dir flash:. The switch file system is displayed:
    Directory of flash:
    2 -rwx 843947 Mar 01 1993 00:02:18 C2900XL-h-mz-112.8-SA
    4 drwx 3776 Mar 01 1993 01:23:24 html
    66 -rwx 130 Jan 01 1970 00:01:19 env_vars
    68 -rwx 1296 Mar 01 1993 06:55:51 config.text
    1728000 bytes total (456704 bytes free)
  7. Type rename flash:config.text flash:config.old to rename the configuration file. This file contains the password definition.
  8. Type boot to boot the system.
  9. Enter N at the prompt to start the Setup program, Continue with the configuration dialog? [yes/no] : N
  10. At the switch prompt type en to turn on enable mode.
  11. Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
  12. Copy the configuration file into memory: Switch# copy flash:config.text system:running-config
    Source filename [config.text]? (press Return)
    Destination filename [running-config]? (press Return)
    The configuration file is now reloaded.
  13. Change the password: switch#configure terminal
    switch(config)#enable password Cisco
    switch#control/Z
  14. Write the running configuration to the configuration file:
    switch(config)#write memory
Jun 07, 2008 | Cisco Catalyst 2926 (WS-C2926) Networking...
Cisco SPA504G IP Phone Logo
3,070 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
