Question about Vacuums
My keurig coffee maker is going really slow all of a sudden .. why would that normally happen
  • 171 Answers
Sometimes they become partially blocked and the best thing to do is run a quarter cup of vinegar mixed with a full pot of water through it empty and repeat if necessary. This will help to clean the tubes out of any residue and help to put it back to normal,
Be sure to run a pot or two of just water through it after the vinegar to rinse it clean of vinegar.
Posted on Oct 07, 2010
I need a downloadable manuel for a Keurig single cup coffee maker Model B40
just go to keurig.com - they have manuals you can download there
the "b40" is the "elite/b40"
morelater
the show doctor
Aug 16, 2011 | Vacuums
My Keurig coffee maker is not brewing. The word prime is on the screen. How do I prime the unit.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 14, 2011 | Vacuums
I have the Platinum keurig and the water is going back into the reservoir and not into the cup??? is it beyond repair?
Are you getting a message saying to "de-scale" it may need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off, keep making partial cups & just not working properly. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir.Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This may eliminate your problem & should be done every 2-3 mths. If that doesn't solve it - your Keurig may already be too far gone. Good Luck.
Jul 09, 2011 | Vacuums
Shows that it is ready to brew, but says "de scale"
What model do you have? I'm guessing we are talking coffee maker, is it a Keurig? If you're getting a message saying to "de-scale" it need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup or filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths, regardless of whatever the model of coffee maker you have. Good Luck.
Jul 08, 2011 | Vacuums
Regardless of setting, I have not been able to get any more than 1/4 to 1/3 of a cup of coffee. The water barely comes out and now the descale message is on the screen. I need instructions for...
Although this is in "Problem with Vacuums," I found it while searching for a solution to my steam cleaner vacuum problem. You must be talking about a Keurig or Breville-Keurig coffee maker. Tap water, especially chemically softened tap water, contains minerals that require periodic descaling, as often as every two months if you make only a couple of cups a day.
Filling the tank with white vinegar and making multiple large mugs without a Keurig coffee cup in the holder will remove most scale. There are products that claim to do better than white vinegar if this does not work. Amazon sells a couple of brands in its Keurig section.
It will take several tank fulls of clean water to rid the machine of the vinegar or commercial cleaning solution. Use distilled water for this. Then switch to good bottled water without a heavy mineral load.
Jun 13, 2011 | Vacuums
We have a Keurig Elite model# B40 that we've had for a little over one year. Because we do not drink coffee, the machine is only used when we have company. Now, when we turn on the power, nothing happens...
My suggestion is to purchase a different unit. It sounds like the circuit board in this one is problematic and it will cost you more to repair that than purchase a new coffee maker.
Feb 20, 2011 | Vacuums
How do I clean my Keurig coffee maker?
I clean my Mr Coffee by pouring a half water/white vinegar into the water holder andturn the coffee maker on andlet the vinegar do its thing. A refill with a little lemon juice in the water gets rid of any vinegary smell left behind.
Jan 04, 2011 | Vacuums
B77 Keurig coffee maker won't dispense coffee if k cup is in holder. Help?
I had the same problem with my Keurig coffee maker. The needle is clean, and no deposits. Above the needle is a check valve. This is a simple fix. Open the K-cup arm and look up, in front of the needle housing is two silverish screws. Remove them and lower the arm but don't lock. Slide the black top cover out to expose supply hose and check valve. Carefully cut the zip tie and remove hose from check valve. Remove the two scres holding the valve in place and drop it down and out. Blow into the end where hose attaches. You should be able to blow thru, with some resistance. If you can't, thats your problem. Take a paper clip and carefully bend and insert into end where hose attaches, pushing ball in valve down alittle. Blow into it again, you should be able to now. If not, keep trying, it will go. When done re-assemble and run a cup of water, with out cup to clean it. Hope this helps ya!
Dec 07, 2010 | Vacuums
Vacuums Logo
169 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
