Question about Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher
Bosch SGS43E02 will not drain - otherwise seems fine Any help? Thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
Bosch exxcel dishwasher SGS43EO2 not heating water.r
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 20, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Can you advise what amp rated fuse is to be fitted on ther plug
Hi, You will need to fit a 13amp fuse the the plug for this appliance.
Hope this helps.
Feb 12, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
SGS43E02 dishwasher is blowing the fuse but I can't get into it to see what might be the problem, how do I remove the top and side panels to gain access.
You normally have to remove the back panel to gain access to the other panels. The order is usually, the back panel first, then the top panel and then the side panels. The top panel may be held in place by two screws and then slides backwards to come off.
Feb 06, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
My dishwasher (Bosch 24 in. SHV55M03GB) seems to be retaining water at the bottom after a cycle and will not drain. Will I require a repairman or is it something we can sort? Thanks
Have you recently installed an in sink disposal? This is where your dishwasher drain line should connect to. Just make sure you knock out the "blanking plug" on the disposal, because it is blocked off in case you do not use a dishwasher.
Otherwise, there is a small drain at the bottom of the dishwasher that pumps the waste water out-there is a chance that this pump has gone bad or just become clogged. Unfortunately, there is probably no way around fixing this without having the dishwasher removed from it's position. If you pull the dishwasher out, it will be a lot easier to check out.
Hope this helps.
Mar 01, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Bosch dishwasher Water pump not stopping
Hi.
You need to replace the pressure switch located near to the pump, in the drain assembly.
The main function of the pressure switch is to turn off pump when there is no more water.
The pressure switch can be tested reading ohms on switch contacts and jumping the switch. This must be done by a technician.
You can get parts and a quote on repair calling Bosch at the number listed on the manual.
Regards.
Nov 20, 2009 | Bosch Dishwashers
Bosch Dishwasher will not take in water
Either the pressure is too low, or turned off by accident. Otherwise it could be a faulty inlet valve
Please leave feedback
Thanks
Rob
Feb 13, 2009 | Bosch (1619EVS-RT)
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Water will not drain.
This problem is often due to a blockage in the impeller blades which are located under the filter at the bottom of the dishwasher. Remove the filter and you should be able to get to the impeller by undoing a couple of torx screws. If the impeller has been blocked (this could be by something as small as a grain of uncooked rice), remove the obstruction so the impeller turns freely.
Nov 04, 2006 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
165 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
