Question about Dacor 36 in. EG366SCHLP Gas Cooktop
Our 36" LP cooktop burners sputter as through there is air in the gas line. I've had the line bled, but problem continues. I also removed and cleaned the burner rings; including making sure the small holes in the rings were clear. Anything else I can try?? How could I check to make sure the cooktop was properly nozzled for LP and not natural gas? Could that be my problem? Thanks for any help you can provide.
  • jwchurch Oct 07, 2010
    yes, the lids are all in position and tightened.
    the lids are in position and the rings have all been tightened
    President:
  • 2,777 Answers
Strange, any progress?
Posted on Oct 08, 2010
  • 712 Answers
If there is a small metal lid in the middle of the burner, please check if it is properly kept in position.
Posted on Oct 07, 2010
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    DCS 36 in. CS-366 LP Cooktop ignition
    in that burner something is short check it out
    Dec 09, 2007 | DCS 36 in. CP-366 Gas Cooktop
    Bluestar rangetop clicks several times before igniting
    Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
    Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
    Flame height on my 36 " 6 burner Viking Range Top
    remove the knob, the center shaft is hollow, slide in a small blade screw driver to adjust the flame cheers
    Dec 11, 2013 | Viking VGRT360-6B 36 in. Gas Cooktop
    How do I remove knobs for burners to clean them?
    To remove the knobs from the cooktop you just pull them off. They are only presser fitted on a post.
    Jul 30, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
    When i turn on a burner, it lights, but all 5 igniters continue to ignite
    I have the same problem all but one burner. When using the other burners the igniters keep sparking after being lit. What do I replace?
    Oct 04, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
    Soot deposits from my brand new downdraft jenn-air gas cooktop
    Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
    Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
    Gas igniters on all five burners keep sparking (JennAir CCG556B)
    Try cleaning around all the ignitors at each burner. Look for build up of cleansing product and/or food. Sometimes all it takes is a good cleaning and removal of a buildup to solve this. Worth trying before replacing a bunch of parts!
    K
    Jul 30, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
    Creda 4 burner, converted to LP
    Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
    Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
    Can't boil water on new Maytag Gas Cooktop
    No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
    Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
    Dacor 36 in. EG366SCHLP Gas Cooktop Logo
    64 people viewed this question
    Top Dacor Cooktops Experts
    jdthefixer
    Mike
    Mike
    Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
