Question about Saeco Magic De Luxe Espresso Machine
How does a Saeco Magic De Luxe Espress machine know the dregs drawer needs the be emptied and turns on the light? Does is just count the pucks that are put into the drawer or is there some type of sensor?
  • 1,089 Answers
Simple answer is it counts how many coffees have been made. If you turn the machine off and then empty the dredge drawer the machine doesn't know this. and the light will remain on. Leaving the machine on when you empty the drawer lets the machine know that you emptied it (15 seconds out) and it will turn the light off.
Posted on Oct 08, 2010
After making coffe red ligth is on, coffe is just fine?
Which red light is on? It may be that youa re emptying the dreg drawer with the power off. When you do this it doesn't reset the counter that tunrs that light on
Feb 14, 2011 | Saeco Vienna De Luxe Espresso Machine
Machine won't work due to dreg drawer
Check to see if your machine has an "exit chute" or similar area where from the used pucks are ejected. The area might be clogged with used coffee grinds and causing a false reading from the machine.
Dec 14, 2009 | Saeco Royal Digital Plus Coffee...
Water comes out with the coffee grounds in the dregs drawer
Hi
Inside the door on the right at top center is a lever that goes from - to +. Move the lever towards the + but not all the way.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light
The is a plastic "flag" on the side of the grout bin which may have broken off, if so you will need to order a new one from Gaggia UK in Halifax
Dec 09, 2008 | Saeco Magic De Luxe Espresso Machine
My dregs drawer is filling up with water
Check your brewing unit, make sure the filter on the top is tight.
Jul 05, 2008 | Saeco Magic De Luxe Espresso Machine
Bought new machine yesterday.says ventilate which i did,then jumps to dregs drawer full,which is empty and clean what can i do now?
Are you still having the ventilate sign come on? If so, let hot water run out for 10-15 sec.
On the dregs drawer full message- carefully put back the dump box -making sure it slides in right. This happened to me the first time until I figured it out how to carefully put it back. If it is not in all the way, it will keep giving you that message.
Jun 16, 2008 | Saeco Magic De Luxe Espresso Machine
Dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Apr 06, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Magic
when you put the machine do you have water or steam coming out of the valve if yes the brew unit might be block check it out clean it or unblock it cheers
Jan 31, 2008 | Saeco Magic De Luxe Espresso Machine
Tray and Dregs light flash when machine turns on
You can't make the light go out because the dreg drawer, brewing unit and drip tray, all activate micro switches when they are inserted. One or more of the micro switches have gone open circuit, or they may just be dirty or clogged with coffee granules. You can only fix this problem by opening the machine up.
The light goes out when contact is made with the micro switch. No contact made, no light goes out.
Dec 06, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
134 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
