Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
I have to bang the bottom of the battery yo make the drill work
    Champion:
  • 248 Answers
Could be loose prongs on batt. or drill,take off battery and see if prongs wiggle with your finger.had problem before was trigger though.voids warrenty if you take apart to try to fix.Very hard to put back together properly
Posted on Oct 09, 2010
BATTERY CHARGER STOPPED WORKING. MANUFACTURERS SAID WOULD BE 2 YEARS BEFORE SUPPLIES WOULD BE AVAILABLE.ANY ONE KNOW HOW TO FIX A CHARGER ??? OR MAKE ONE ?
You don't say which make and model number. Sometimes it is just the fuse inside, but be careful when changing it as when you turn it on again the PCB can go bang due to a fault on the board.
Jun 01, 2012 | Drills
Makita Drill's battery is stuck on
IT IS THE DUST THAT IS CAUSING THE PROBLEM. YOU COULD TRY HOLDING THE LATCH BUTTON ON THE BATTERY AND THEN BANG THE BACK OF THE BATTERY AGAINST THE WORK SURFACE TO KNOCK IT OFF. CLEAN IT UP AND TRY A LIGHT SPRAY OF MR SHEEN. DUST WILL STICK TO ANY WET SURFACE SO NOT A LOT.
May 27, 2012 | Makita 18V LXT Lithium - Ion Cordless...
Hi, Where can I get a replacement battery charger for my 18 volt DC cordless? Model # SBD218TK serial # 012765. I live in Dunedin, New Zealand. Cheers, Peter.
Yo Mate, Have you tried contacting Ryobi online. GIve it a try, They have xlnt cust service.
...............dansky66
Mar 26, 2011 | Ryobi Drills
Lithium-ion battery will not charge, drill has not been used for a couple of months so placed on charge for most of yesterday, battery no life at all. Regards Chris
I think you've already come to this conclusion, so I'll affirm, you need a new battery.
Something that may be worth trying, if you haven't already, find something a little abrasive and try to really scrub the contacts on the drill, and in the charger, ( obviously you'll want to make sure the charger is unplugged.)
Jan 24, 2011 | Ryobi Drills
My 12 volt Ridgid drill just quit alltogether. I know it,s not the battery or charger as I have an identical drill and it works just fine. This drill takes the small cartridge type battery. Any...
To start, I assume you took the "good" battery from the working drill and tested the inoperative drill.
Good for doing that.
The other causes I know of in Drills that turn them into paper weights are as follows:
1 Worn Brushed: You can attempt to test this by squeezing the assumed good trigger button and
Taping the drill or lightly banging it on a bench top or something else. If it is brushes, it will often but no necessarily all the time, start to run for a moment, or just running. Since you use the drill and "use it a lot" That will be the first thing I would look for.
2 Trigger Button.
I would bring it to a tool service place or send it back to Ridgid. Try this link
http://www.ridgid.com/Tools/Technical-Services/index.htm
Hope this helps, Happy New Year
Mark
Jan 01, 2011 | Ridgid 12 Volt Cordless 3/8 In. Drill
I have a 18v battery charger for my great neck drill but the red light insant lighting up when I go to charge my my battery, but the green one is lit up.
Try jump starting the battery. Li Ion batteries often have smart chargers if the battery gets to low the charger doesnt recognise it. If yo have a spare battery fully charge it ant then conect + to + and - to - with wire ( may take two people) kep them connected for 2 mins or so then try in the charger.
Worked for me
Dec 17, 2010 | Great Neck 80125/79681 Cordless 18V Drill
The problem is that after Ive charged the
buy a new baterry. charged 12 V batteries voltage must be 14.45 V
Sep 25, 2009 | Drills
Just prchased panasonic 14.4v drill/driver, charging battery, the top light and ver bottom light come on but the third light from the top, "battery now charging" light does not come on.
yes, worked it out, it was a legend of the bottom lights` status. they wern`t lights that were supposed to come on.. a bit embarrassing actually.. too many years using bad tools.. lol.
Mar 23, 2009 | Panasonic 14.4V Lithium Ion Drill Driver...
Bang
yo can try pulling off hte lower access panel 3 screws across the bottom panel, from there yoll be able to see whathappened, perhaps he shock aborbers snapped off, if not htere is a spring that the tub hangs from mounted across the top of frame. 1 on each side
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
