Question about Husqvarna Chain Saw 20" Bar
What is a needle bearing in a stihl chainsaw and what does it do
  • 26 Answers
Http://www.ecrater.com/p/6962460/024-026-stihl-325-sprocket-w-needle-cage-38076-2?keywords=stihl%20caged%20needle%20bearingthis bearing(on the right) fits inside the sprocket (on the left)allowing minimal friction. Without it, the sprocket spins so fast it would melt all the plastic around the sprocket(seen it)
Posted on Sep 21, 2011
Where to get points for 016 stihl chainsaw?
Stihl Chainsaw Parts ' Chainsaw Parts ' Discount Online Parts
https://www.discountonlineparts.com/chainsaws/?b=stihl
  1. Cached
  2. Similar
Quality Stihl replacement parts, cheap and quality available online.Handlebars and Housings · ‎Bar/Chain Combos · ‎Stihl 041 Cylinder Assembly ...
Stihl Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b354/Stihl-Chainsaw-Parts
  1. Cached
Stihl Chainsaw Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Chainsaws ' Parts, Accessories, Reviews & Pricing ' STIHL USA
https://www.stihlusa.com/products/chain-saws/
  1. Cached
Choose from the wide selection of reliable, dependable and high performing STIHL chainsaws with low-emission technologies and quieter, more fuel-efficient ...Homeowner Saws · ‎Professional Saws · ‎Farm & Ranch Saws · ‎In-Tree Saws
Stihl Chainsaw Parts ' eBay
www.ebay.com/bhp/stihl-chainsaw-parts
  1. Cached
  2. Similar
Find great deals on eBay for Stihl Chainsaw Parts in Garden Chainsaws. Shop with confidence.
Home ' STIHL
en.stihl.ca/index.aspx
  1. Cached
  2. Similar
STIHL - Information about the STIHL Group and our extensive range of chain saws and ... About us More than the world's most successful chain saw brand. stihl chainsaw Google Search
Nov 23, 2016 | Stihl Garden
Stihl chainsaw 011 bearings scattered inside engine.
The crankcase will need to be split, then inspect the crankshaft for damage where the bearing contacts it.
Replace the bearings, seals, and case half gasket.
Nov 14, 2016 | Stihl Garden
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
Clutch bearing seems to be sticking
sounds like its on its way to seizing up, either damaged bearing or piston
Jan 17, 2016 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Changed carb on a stihl 025 from a single set screw to a double set screw . what settings do i need to start initially
on the needle setting closest to engine(air) it is turn clockwise till it stops, then open it up counter clockwise 1 turn. The second adjustment needle, should be turned clockwise till it stops, then opened up 1 1/2 turns. Adjust the second or gas, until your engine sounds like it is running it's best.
Dec 06, 2013 | Stihl Chainsaw 42mm Piston Rings 025 O25...
How do you change the clutch?
Remove the side casing. (bar side)
Take off bar and chain.
Remove E-clip holding the clutch drum on.
Remove clutch drum and needle cage bearing.
This should expose the clutch.
Remove spark plug.
Use a piston stop to stop the piston rising, Sometimes a knotted piece of pull cord fed into the cylinder is just as good.
Turn the clutch clockwise with a socket to unscrew.
To put clutch back on turn anticlockwise till piston cycles back and hits the piston stop again and tighten. Replace spark plug and clutch drum, bearing, bar and chain and side casing.
Mar 15, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl HT 75 pole saw throttle induces stop
If it dies when you hit the throttle, put a kit in the carb and clean it.
Oct 16, 2012 | Stihl Chainsaw Pole Pruner Ball Bearing Ht...
Chainsaw will not run once you take the choke off.... runs good with choke on. walbro wa2c for stihl 031av chainsaw
Most likely the fuel filter in the tank is plugged you can get it out with a pair of needle nose pliers and buy at any saw shop. Hope this helps.
Jan 19, 2010 | Garden
Crankshaft bearing gone need manualto strip it
Stihl IPLs are proprietary and not available on line. Please make your request here:
http://www.stihlusa.com/contact.php
You might also look here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
It is collection of chainsaw enthusiasts with a few professional 2-cycle mechanics thrown in for good measure. What you propose has been discussed many times.
HTH
Lou
Dec 05, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl ms290 chain runs constantly even when idling and when u put the chain brake on it kills the saw
The centrifical clutch is probably rusted (or has a broken spring). You can try a small amount of WD-40 inside the clutch to see it that will break it loose.
Also, be sure that the chain tension adjustment is not too tight!!
Oct 10, 2009 | Oregon Scientific Oregon Chainsaw chain...
Husqvarna Chain Saw 20" Bar Logo
193 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
