Question about Balboa Instruments Duplex Digital Panel 2 Pump
I have a cal spa hot tub. I purchased a new motor with new dual pumps and installed on it. My motor is 240 volt 2 speed. When its on the high speed will only stay on a couple of minutes and then kick to low speed. If I have it on low speed it stays on that forever. IT doesn't matter what mode I have it in. I just had the circuit board checked out and it was fine. Could it be the topside control panel? last winter I did have it on constantly so it would freeze up. Could it have got stuck in that mode?
5 Suggested Answers
  • 990 Answers
SOURCE: We recently purchased a Balboa
This is probably just a programing issue. You should see if your neighbors still have a book for the tub. If not you can probably get one on line. You will need to try Balboa with the year and model #. You will also need to check your control box in case it comes from another manufacture. Make sure that you use all the numbers and dates on the box as they can change things a couple of times. Mine is a five year old sundance and for the model I have they had three books for that year and two styles for one and two motor models.
When you get one go to how to clear memory then start from scratch. It may seem like a pain now but when you get hot bubbles at the push of a button you forget all the trouble.
Posted on Oct 20, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Keys hot
Is the motor wired for 220v or 110v ??? You may have 110 to the motor, but if it is a 220 motor it still will not run and the 110 of the one leg will still feed back through the motor...
Check the voltage that is supposed to be coming out of the board and that the motor is wired for the correct voltage...
Also check that the fuse on the board did not blow...
most boards have a fuse on the board that will blow is a situation like that...
heatman101
Posted on Mar 26, 2011
SOURCE: I have a 1999 Emerald
Understand that this information isbeing provided as-is and without warranty or guarantee. As with allelectrical components and devices, all work should be performed by a licensedspa or pool technician. Serious injury or death can occur if a component isimproperly repaired or installed. This soundslike it could be an issue with the board but there is some testing that needsto be done to determine the actual cause. A spa technician will be required tocome out and verify the wiring to the pump and then typically start testingvoltages off of the board as the unit switches between the relays that controlthe speeds on the pump. You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
Posted on Sep 12, 2011
SOURCE: I have a Balboa R574
Understand that this information isbeing provided as-is and without warranty or guarantee. As with allelectrical components and devices, all work should be performed by a licensedspa or pool technician. Serious injury or death can occur if a component isimproperly repaired or installed. This islikely an issue with the GFCI breaker not being able to handle the load or aproblem with the high speed of the pump.
Hot tub won't heath up cal spa
Could be many things, please explain further.
Apr 11, 2013 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Wiring motor hot tub
The wiring diagram should show on side of motor.
Here is basic motor wiring:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Test each lead as shown in following image. In the case of 240Volt, the 2nd wire is not Neutral, but testing is same.
http://waterheatertimer.org/images/Motor-capacitor2-800.jpg
If you have 2 speed motor, then you will have switch or timer controlling the speed:
http://waterheatertimer.org/images/GM40-wiring-2-speed-pump-400.jpg
Oct 05, 2012 | Waterway 5 Hp 230 Volt 2 Speed Side...
My Cal Spa tub just put in a new dually motor and 6 months later my motor will turn on but just humm for 1 min motor wont turn on, if i hit the button to go on high it turns on then hit the button aga
Sounds like starter switch has failed in the motor. Since it is only 6 mo old, should be under warranty. You can wire it for high speed only and then it will start and run and keep the water warm, just a bit nosier. Possible that you can get a new switch if warranty is out, if you are up to changing it out. You will have to contact the motor manufacturer or their rep to order one.
Sep 22, 2012 | Rotary Spa Pump Dually Pump Cal Spas 110V...
Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Jul 05, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Motor siezed up and will not restart.
Find a local electric motor repair shop and see if the motor is repairable. If not, a new motor and possibly the pump will be required.
Jun 14, 2009 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
Installed new 2 speed motor olny low works
IF the filter is clean, then your problem is electrical. First make sure you are not using an extenesion cord. These pumps do not work well with a cord over 6ft long. Then make sure that the pump is on a dedicated outlet. No Microwaves, computers competing for power. Most likely the pump is not able to draw enough power and is shutting off.
May 30, 2009 | Waterway 1 Hp 115 Volt 2 Speed Side...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
88 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
