Question about Haier HDN455 Dehumidifier
Haier dehumidifier HDN 305 Fuse Replacement
My dehumidifier has not light and makes a click noise when youtry toturn it on. the power outlet works. I checked the filter and it is clean. The Haier Customer Service rep said it was a fuse insude. Can you tell me how to replace the fuse & where it is located inside . Also, where to purchase one? The model is actually a HDN 305 , small unit
SOURCE: Need parts
You can also find the part at www.partsquik.com. Order part# AC-3050-02.
Posted on Jul 28, 2007
SOURCE: Haier HDN655E Dead
There is an internal fuse. Take off the outer plastic casing. The fuse is on the bottom of the board on the upper right of the unit. It's a 12 amp fuse. I had the same problem and found the fuse blown.
Posted on Sep 17, 2007
SOURCE: Where can I find the fuse on the panel?
tiewraps.com on the internet, you can purchase a 10 pack of 250volt 12amp fuses. AG-12
Posted on Aug 02, 2008
IrishDruid
  • 2712 Answers
SOURCE: Haier Dehumidifier stuck on 45
Check the coils at the back of the dehumidifier to see if there is any frost buildup on it. If there is, turn off the machine for a while until the room warms up and melts off the frost. The machine works by condensing the moisture in the air over these coils, so if the coils are frosted over, or are not cold enough, the moisture cannot condense. If the coils are not cold enough, you may want to get it refilled with refrigerant. You will need to take it in for servicing in this case.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 29, 2008
IrishDruid
  • 2712 Answers
SOURCE: HAIER HD656E
It looks like there is a short somewhere in the machine's circuitry. You will need to get this serviced by a qualified technician.
Why does the power light on my dehumidifier flash quickly?
without the model number I cant be 100% sure , but due to your description of the last thing u did , Id say the light is flashing indicating that the water catch bucket is not installed correctly back as it was before , most units have a safety that wont allow a unit to operate unless the water catch bucket is installed and M/T as this would allow it to dump water to the floor if it were not
Nov 24, 2015 | Dehumidifiers
Why did my dehumidifier suddenly stop dehumidifying, fan works fine
check that the tank isn't full or the outlet hose is not blocked. Remove the filters and clean if required.
Jul 27, 2014 | Fedders A7DH45B2A Dehumidifier
Plug the unit in, hit the power switch nothing not even the lights for the buttons.
Check the outlet that the unit is plugged into, to make sure that it has power. The circuit breaker for that outlet may have been tripped. Also make sure that the outlet is not damaged inside or there could be a loose wire connection or a frayed wire to the outlet.
Hope this helped you to start troubleshooting and solving the problem.
May 18, 2011 | Kenmore 54501 Dehumidifier
I have cleaned the filter that is located in the front; however it still won't turn on, what could be wrong? thank you
If you're not getting any indicator lights, check the receptacle that it's plugged into. Is their power to it? If not, the circuit breaker in your home's circuit breaker panel may have been tripped. Or the outlet itself may be faulty (loose wire, poor connection, etc). If the indicator lights are working, but the compressor is not, turn the Master ON/OFF switch on the unit to OFF and wait 10 minutes before plugging it back in. This will give the electronics time to reset themselves.
Hopefully, the above will solve you problem.
Mar 24, 2011 | LG LHD659EBL Dehumidifier
My HDN455E dehumidifier stopped working the other night. When I turn the knob to "on", it makes a clicking noise, but does not turn on. The plug works fine, there is no water in the bucket, and I've...
check the capacitor to the conpressor motor BUT IF YOU ARE A NOVICE STAY AWAY FROM THIS PART IT CAN BLIND YOU OR EVEN KILL YOU and its not worth that Truely its sounds like the capacitor is shot or ven worse your compressor mother is shot have a technition check it out it is really worth it. PS Im not jocking about the capacitor.
Aug 18, 2010 | Haier HDN455E Dehumidifier
How do I clean the dehumidifier?
A dehumidifier works just the way an air conditioner works but in a reverse manner. If you encounter a problem with your dehumidifier then it would be repaired the same way you would repair an air conditioner. As such a dehumidifier does not require much cleaning apart from changing the filter. When the filter and coils of the dehumidifier are choked with dirt, it may not pull out moisture from the air properly. The efficiency of the dehumidifier gets decreased and the only solution is, to clean it thoroughly. In order to assist you with the cleaning procedure of a dehumidifier, following are a few tips:
  1. Remove the water tank/container and clean it after draining the water. Depending on the usage the container must be cleaned regularly.
  2. Cleaning or changing the filter is also important for the main function of ensuring a healthy atmosphere is performed by the filter. Mix some bleach with warm soapy and clean the filter. It will help to get rid of the bacteria, molds and mildew.
  3. Use a vacuum cleaner to clean the evaporative coil/hot coil. Scrub off the dirt using a brush but make sure that you don’t bend the fins while cleaning.
  4. Clean the condenser or the cold coil the same way. If the humidifier is working in a room where the temperature is below 60 degrees Fahrenheit then check the coils whether it is not icing up.
  5. See to it whether the fins are bent or not, if they are bent then straighten them out using a fin comb otherwise it might obstruct the effective working of the dehumidifier.
  6. And yes do not forget to clean the fan blades and other parts of the dehumidifier.
  7. Keeping in mind the humidity level of your room, sets the humidistat of the dehumidifier as keeping it too low or too high may only make the dehumidifier to run longer than necessary.
Also before you start with the work of cleaning the dehumidifier, make sure that it has been unplugged.
Aug 17, 2010 | Fedders A7DH45B2A Dehumidifier
My DeLonghi Portable Dehumidifier Model DEM10 has stopped working. It doesn't make the same noise when you turn it on anymore i.e the slight refridgerator sound. Does this sound like a repairable problem...
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | DeLonghi Dehumidifiers
I have a LG LHD45 EL dehumifier, stopped working suddenly
Check the glass fuse on the circuit board inside the power supply at back of unit (have to take off cabinet)
Dec 03, 2009 | LG LHD45EL Dehumidifier
Haier HDN455 Dehumidifier Logo
209 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Mike Squire
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
