Question about LG LRSC26910 Side by Side Refrigerator
My LG fridge is freezing my food. Model # LRSC26925TT
  • 330 Answers
SOURCE: Have a 2005 model#LRSC26925TT LG
When you order the new replacement, did you ask the supplyer whether it can be replace the old panel? Sometime the wireing inside is different, I do not suggest you touch it unless you got the panel is completely same size and same founction and you know how? Otherwise it is a headache.
The panel must be right one.
Posted on Jul 21, 2008
Sea Breeze
  • 4655 Answers
SOURCE: food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Posted on Aug 13, 2009
SOURCE: LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Posted on Jan 05, 2010
My Lg fridge Model # LFX25980ST is freezing my food in the lower portion of the fridge
Lower the number on the temp dial or replace the thermostat.
Jan 03, 2017 | LG Refrigerators
My LG 693 LTR fridge freezer model no P247STSL is freezing the food in the fridge and building up ice in the fridge on the left side of the drawers on the wall on the side of the freezer, sometimes the fan...
The reason why fan is making loud noise is because of the ice built up on the coil because of freezing.
You can check your drain line to see if it's clogged and clean it out .
There are several video on you tube showing you how to clean drain line.
Hope this help
Jun 02, 2017 | GE PSS25SGN Side by Side Refrigerator
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Model# LRSC26925TT freezer and fridge wont get cold enough to maintan food for more than a day or two. freezer doesn't make ice either anymore.
sounds like the fan motor in the freezer is not working is it running ? if not turn off frig.let it defrost manually, open doors. find the motor. see if you can turn it.. if it turns. restart frig .see if it starts. if not. new fan motor is needed.good luck
Aug 21, 2010 | LG Refrigerators
Lg fridge freezing food in freezer section
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for
the cold control and the air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control
Hope this helping solving the problem.....
Aug 15, 2010 | LG LRSC26922S Side by Side Refrigerator
My LG French door fridge, the food freezes when it is placed near the back of the fridge.
There are three possible causes for this:-
1. You have food in contact with the cooling plate at the rear of the fridge, or very nearly so: it should always be at least an inch away and most fridges have shelves designed to assist this.
2. You have the fridge thermostat set too low.
3. You have overloaded your fridge and so the very cold air at the back of the fridge cannot circulate, creating a local zone which is far too cold.
Your fridge instructions will usually have warnings advising how to avoid these problems.
Some fridge models rely upon circulation fans to ensure an even temperature distribution and these may fail to produce the same effect, but such models often (not always) have an audible or visual warning if the fan(s) have failed.
Unfortunately you have not specified your precise LG model number so it's impossible to be any more specific.
Aug 15, 2010 | Kitchen Ranges
Food in the fridge part keeps freezing even with setting at highest temp
if its at the highest setting, i.e., the largest number or letter, you have it at the COLDEST setting, and it will freeze in the refrigerated secion. Reset all controls to normal, which is the middle setting. so if your scale range is 1-9, middle setting would be 5, if scale is A-E, middle is C and so on.
After you reset controls, it will take 24 hours for temps to balance themselves out. Your food may take longer to thaw out, so dont go buy whether food is still frozen, instead place a thermometer in the center of the fresh food side. your fridge temp should be in the 35-40°F range. If after 24 hours your fridge section is still below 32, Then you do have a problem, but LG is not a simple unit to diagnose, impossible to do without inspection.
www.FixMyFridge.net
Mar 08, 2010 | LG LRSC26925 Side by Side Refrigerator
Jul 08, 2009 | LG Refrigerators
Have a 2005 model#LRSC26925TT LG fridge with front ice&water disp. and digital panel. Ordered replacement funnel and frame since mine is outdated and need to replace. Can we replace on our own and...
Jul 21, 2008 | LG Refrigerators
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
LG LRSC26910 Side by Side Refrigerator Logo
140 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
