Question about Epson Stylus Color 740 InkJet Printer
Paper feeds through crooked and comes out crunched
Hi, Out of the blue, the paper will not track evenly thruogh the printing process on my Epson Stylus color 740. It pulls through correctly on the left side but does not pull through, then crunches up and feeds through crooked and crucnhed up on the right corner. I can find no obstruction inside the paper feed chamber. Not sure how to access the rollers to check. Paper jam has been cleared- problem continues.
  • 1 more comment
  • Anonymous Jun 23, 2008
    same problem
  • lauramye Jul 10, 2008
    the paper is feeding crooked, I have looked for paperclips or anything but can't seem to resolve. HELP
  • lanrui Sep 07, 2008
    i have the exact same problem even though the blue guide is in proper position
Hi - googled and found a good Epson site with info on this - reproduced below - the part that worked for me was allowing a small bit of room between the paper on both sides and the paper guides (counterintuitive...) rather than flush up against them.
From the Epson instructions:
You can try using the Epson cleaning sheet (has a sticky side) to pick up any excess paper residue. It's available from the Epson Store.
Try loading heavier stock paper, such as 24 lb. paper, if you haven't done so already.
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Posted on Sep 07, 2008
  • 4 Answers
Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
Posted on Sep 04, 2008
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
May 15, 2016 | HP OfficeJet 7310 All-In-One InkJet...
Epson wf-2530 printer error see your documentation
Turn the printer unit ON
2. Pull the power plug from the back side of it
3. wait 1 min
4. Plug unit back in
5. wait 3 full minutes
6. try to print does the error still exist? If yes continue below
Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away.
If you continue to experience problems, PLEASE RESPOND TO ME
Dec 16, 2013 | Epson WorkForce Office Equipment &...
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
My CX9400Fax printer has a paper jam every time it tries to print. As the paper starts to feed into the printer, the bottom left pulls in and the paper is then feed in crooked causing a paper jam every...
hi
hey i had the same prob til about 5 minutes ago ,, i kept pulling and playing with the jammed paper under the lid where you change the ink,, and finally on the left side ,,a blue piece of soft plastic material came out ,,now it works great ,,i have no idea where it came from but maybe it will help you lets hope
Dec 13, 2009 | Epson Stylus CX9400 Photo Printer
Paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper feeds crooked
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Alignment page is printing crooked
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 06, 2009 | HP PSC 750xi All-In-One InkJet Printer
Epson RX520 dont print the full picture
It's a problem with the paper not feeding straight. The printer will make a pass & sense the width of the paper & print accordingly. If it feeds in crooked then it sees it as being narrow & only prints to that width. Happens more easily with heavy photo paper.
Apply a bit of pressure to the paper as it feeds & it's happy days.
Feb 20, 2008 | Epson Stylus RX500 All-In-One InkJet...
Misaligned Printing
if you do an internal test page ( there should be a button on the machine you push for this function, I'll give you the link for the manual in case you don't have it) does it come out crooked?
the alignment of cartridge is to make sure the colors are o.k. not for paper alignment.
if the internal test comes out ok then the problem is with the paper path, are the guides snug against the paper ?
if the internal test comes out crooked then the problem is with the scanner or board.
Dec 06, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Epson Stylus Color 740 InkJet Printer Logo
816 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
