Question about GE JVM1630 Microwave Oven
Does not heat or get anything hot - GE JVM1630 Microwave Oven
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 07, 2010
I have a Panasonic inverter microwave. Was working perfectly an hour ago. Now totally dead. There is no light or anything. Have checked plug and fuses. No smell or anything. Can you please help.
Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
Jun 20, 2017 | Panasonic Microwave Ovens
I have a sharp R 350 l. when i switched it on to heat some food it ran for about 10 secs then a loud bang.All functions work except that it wont heat anything.
Sounds like an electrolytic blew, but it could be any number of things. (Failure of one element could cause the failure of others, such as the magnetron, as well.) You could have it looked at, but if it's an inexpensive table-top microwave, it's less expensive to just go buy another.
Apr 13, 2014 | Sharp Microwave Ovens
Lite bulb broke.
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Jan 08, 2013 | Frigidaire PLMV168 Microwave Oven
Hi at the back of my fridge freezer i think the compressor at the bottom is very hot, also the small pipes at the back is not heating as much as the compressor, actually anything but hot but not cold...
It possibly needs re gassing. Call a refridgeration expert in to look at it for you, there is nothing you can do without the gas bottles and evacuator.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 14, 2010 | Emerson Microwave Ovens
Microwave Won't Heat
Check the door safety interlock switches. Be careful of the capacitor, potentially dangerous.
If the switches dont make a connection, the magnetron will not energize ... no heat
Apr 19, 2010 | Microwave Ovens
Microwave oven trouble
Obviously, heat escaping from anything heated in the oven will indirectly heat the walls and the magnetron is not 100% efficient so it radiates a good deal of heat but that is normally carried off by the cooling fan and exhausted into the room air.
Oct 30, 2008 | Kenmore 63252 Microwave Oven
Emerson Microwave Oven and Grill MWG9111SL
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
kgjlkglj
Jun 10, 2008 | Sharp R-308H Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
GE JVM1630 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
