Question about Maytag LSG7806A Front Load Stacked Washer / Dryer
Hi maytag lse7806gge in order to pass thru a door frame a smart tech removed the outer casing of the dryer which gave the additional 6 or 7 cm needed to clear the door frame this tech is nowhere to be found and i would like to find out how to remove the outer panels WITHOUT having to touch any of the mechanical or electrical systems - just the panels - i've seen a blow out but couldn't figure out anything beyond the 3 screws at the bottoms of the front panel any help thanks
  • nayadn Oct 07, 2010
    thanks but that's not it
    it describes how to remove the tub - i don't want to touch any inner parts only the panels
    and possibly the top lid
    i know for a fact that the machine WITHOUT THE PANELS is much narrower which will allow it to go thru the door frame - from side to side the washer is app 69 cm - door frame is 61
    it did go thru before (without the top dryer)
    so - front / side panels / and possibly the the top lid - all this without touching any systems either electrical or mechanical
  • Maytag Master
  • 3,740 Answers
Download this manual http://www.servicematters.com/maytag_library/docs/16000416.pdf
All the dryer information starts on page 57. There is nothing in the manual... (our bible) that mentions complete chassis removal.
The majority of the screws that have to be removed for outer chassis removal are in the back of the unit. Yes there are others in the front. Follow the chassis lip seam and remove the screws securing the seam only. It is difficult to explain because it is so rare that this has to be done. It is kind of I have to be there to do it things and just figure it out. I have done it less than a hand full of times in 40 + years of working on home appliances.
Thanks for choosing FixYa,
Kelly
Posted on Oct 08, 2010
    Brigadier General:
  • 3,513 Answers
Please check the bellow link related to your issue:-
http://www.ehow.com/how_5592752_remove-maytag-washer-wash-tub.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 07, 2010
How do I reverse the door on my Whirlpool Duet WED9270XW dryer?
George, try the following-- hope it helps!
Things You'll Need
  • Torx T25 screwdriver
  • Phillips screwdriver
  • Large towel
Instructions
    • 1 Remove the four Torx screws holding the door hinge to the dryer. Lift the door up and pull it away from the dryer to remove it. Lay the door face-down on a large towel to protect it. Screw the four Torx screws back into the holes in the dryer.
    • 2 Remove the two Trox screws holding the door strikeplate onto the dryer's door jamb. Remove the strikeplate and install it on the opposite side of the door jamb.
    • 3 Remove the Phillips screws along the inside of the door. Lift the inner door up and remove it from the outer door. Remove the six Phillips screws along the outer window retainer. Rotate the outer window assembly clockwise until the tabs on the window line up with holes on the frame, and lift the outer window retainer up and off of the window's trim ring.
    • 4 Rotate the outer window itself 180 degrees to rotate the handle to the other side. Replace the outer window retainer and rotate it counter-clockwise to lock it into place. Replace the six Phillips screws.
    • 5 Remove the Torx screws holding the hinge and latch plate in place. Reinstall the hinge on the opposite side of the door. Reinstall the latch plate on the opposite side of the hinge. Slide the inner door back into the outer door and replace the Trox screws.
    • 6 Remove the four Torx screws on the hinge slot on the door jamb. Slide the door into the door jamb and replace the screws
Jan 11, 2015 | Whirlpool Washing Machines
Tip
Replacing the inner door glass.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
on Apr 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
Cannot get dryer door to close/latch properly.
Hi stay at home MOM
  1. what is the Model of Dryer?
  2. do you pull to open or push button to open DRYER Door?
  3. hinges on the right or the left?
  4. door inner n outer panels plastic?
  5. is there a door seal on the door?
  6. when you did your removal of lint, did you remove DOOR?
  7. picture front of dryer area and door of dryer will help.
Sep 27, 2014 | Dryers
How do get into this dryer? Is there a secret to opening it?
1st remove outer door 17 by removing screws from 2 hinges so that you can remove front panel 24. Then remove drum support 6 (bottom pix) so that you can remove belt 18c9ql4ekhbnniaaaaaelftksuqmcc
6rdyt7bom98aaaaasuvork5cyii=
Jun 24, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
May 02, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
How do I remove the front panel?
Hello, maytag makes it very hard to get to the lint.
You need to first take off the door, then the outer frame. The door has 4 philips screws and the frame should have 4 also. Good luck :)
Sep 15, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
Glass is shattered to to replace
dd5ebd3.gifclick here
Inner Door Glass
May 15, 2009 | Maytag MER5765RAW / MER5765RAQ /...
Inner door glass replacement
3 Remove the inner screws. Keep all set of screws ordered, and take note of the order you remove them. You will follow reverse order in reassembly.
Baffles are loose on my dyer maytag neptune mde5500
Hi Nick, welcome to FixYa!
1. Open the door and remove the two screws that secure each of the door hinges to the dryer frame. With the door open so you can take a hold of it, simply pull the whole door out of the notches that the hinges fit into.
Next, remove the two screws on the opposite side of the frame where the door closes to. (along with the two white plastic trim pieces the screws go thru) Once the door is off and the screws are out, pull the entire front panel forward and then it will lift off the tabs at the bottom and you can set it aside.
next, look up near the top of the cabinet, on each side, for the metal hooks that secure the top to the cabinet. Remove the screw (5/16" nut driver) that secures each hook to the cabinet. Take the hook off, repeat for the other side.
Now you can lift up the top of the machine, and rotate the drum so that the loose baffle is at the top so you can work on the baffle easily. Rotate the drum to the next baffle, etc.
I hope you find this answer helpful.
Dec 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag LSG7806A Front Load Stacked Washer / Dryer Logo
133 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
